mad-butcher
| posted on 18/11/04 at 07:07 PM |
2 stupid questions
1. on a blade powered indy what thickness and made of what is everyone using to space the prop centre bearing from the mounting plate is 25mm
enough
2. which is the fuel feed on the blades carbs the bottom one or the top one...
don't forget i'm that old the only carbs i've worked on are the old amal monoblocks
tony
shortie
| posted on 18/11/04 at 07:27 PM |
Hi Tony,
Not sure about the prop centre bearing spacer, was thinking the same question myself!
Fuel inlets are the bottom hoses on the carbs, top is breather.
HTH,
Rich.
| posted on 18/11/04 at 09:42 PM |
Our propspacer is made from Aluminium plate 9.5mm thick x3 = 28.5mm
HTH
