New Topic New Reply
Author: Subject: MK Interior trim
whitestu
posted on 22/11/05 at 09:34 AM Reply With Quote
MK Interior trim
Does anyone know if the plastic interior trim included with the deluxe kit includes interior side panels - I phoned MK and they said it didn't, but they didn't seem too sure. The pieces I got in my kit are the rear panel and four pieces for the transmission tunnel.
Stu
donut
posted on 22/11/05 at 09:38 AM Reply With Quote
If you mean the side pannels that attach inside the car on the drivers right and passengers left then yes you should have some in the delux kit, well i did!
welderman
posted on 22/11/05 at 09:41 AM Reply With Quote
Mine came with all the inside panels in the Delux kit
Thank's, Joe
I don't stalk people
ReMan
posted on 22/11/05 at 09:46 AM Reply With Quote
And mine!
Worrying
www.plusnine.co.uk
∙،°. ˘Ô≈ôﺣ
zxrlocost
posted on 22/11/05 at 10:07 AM Reply With Quote
unorganisation again
I am with whitestu
large rear panel and 4 transmission tunnel parts
ditchlewis
posted on 22/11/05 at 10:57 AM Reply With Quote
Mine also, but i used them all as templates to cut aluminium panels. and then covered the plastic with vinyl trim which is easy to remove.
Ditch
scotlad
Contributor
Posts 781
Registered 30/9/03
Location Edinburgh
Member Is Offline
Photo Archive Go!
Building: Built MK Indy Blade, RH 2b Zetec, rebuilding locos
posted on 22/11/05 at 11:20 AM Reply With Quote
Mine certainly did
greggors84
posted on 22/11/05 at 11:39 AM Reply With Quote
In mine i got 5 ali panels, one for the rear bulkhead behind the driver, then ones for the left and right of the driver and passenger. Didnt get a tunel top though.
I didnt get any plastic interior trim, but i did get my kit 2 years ago.
Chris
The Magnificent 7!
Jonte
posted on 22/11/05 at 12:03 PM Reply With Quote
My Deluxe kit that arrived in febraury 2004 included interior trim panels in plastic.
Only used the parts for the tran tunnel yet
whitestu
posted on 22/11/05 at 12:23 PM Reply With Quote
I have clarified this with Phil at MK. He says that the side panels are no longer included. They recommend trimming the sides with carpet as a neater solution.
Stu
asn163
posted on 22/11/05 at 12:24 PM Reply With Quote
I got the rear and tunnel plastic panels but no sides.
zetec
posted on 22/11/05 at 09:57 PM Reply With Quote
Knock up your own, you can get what you want and it doesn't cost much. Making my trim infill panels (for trimming side panel insides) was far easier than getting the single piece ones to fit I had first time round!
" I only registered to look at the pictures, now I'm stuck with this username for the rest of my life!"
New Topic New Reply
