<<  1    2  >>
New Topic New Reply
Author: Subject: What exactly comes in the full kit
ed_crouch
posted on 30/1/06 at 01:38 AM Reply With Quote
Chaps,
Contemplating putting in an order for full kit when I get back to blighty.
My question is, will I need extra aluminium sheet to plate the chassis behind the seat backs, or is this included in the kit. Also, when they say engine mountings on the pricelist, do they mean rubbers, or the steel (alloy?!?) brackets?
A little confused over what I get for £2495
Ta.
Ed.
[Edited on 30/1/06 by ed_crouch]
I-iii-iii-iii-ts ME!
Hurrah.
www.wings-and-wheels.net
phoenix70
posted on 30/1/06 at 08:29 AM Reply With Quote
The full kit is pretty good, but you will need a lot if extras, but thats down to your own choice. The Indy use GRP panels with plastic interior panels, so all the panels except the dash are included, but you might want to change some panels from GRP/Plastic to Aluminum. The engine mounts are complete including the rubber and steel. I got my kit just over a year ago, so my info might be a little out of date, but what you get in the full kit is: Body Panel (Int/ext) except boot cover/box
Full set of wishbones inc Ball joints
Full set of Coil over shockers
brake line kit (All the brake pipes)
Rear Uprights
Pedal kit (clutch, brake,accel)
Also they will modify an standard Sierra steering rack to fit (including track rod extensions), and modify the front upright off of your donor
The MAJOR parts you don't get are
Seats
Fuel tank (in fact no fuel system at all)
Any electrical (except the pressure brake switch) i.e. lights gauges etc.
Dashboard
Wheels
and of course the parts off of your donor.
I;m sure someone else will point out anything I've missed off.
posted on 30/1/06 at 11:25 AM Reply With Quote
Nuts, bolts, washers, rivets, p-clips, hoses, loom, pu adhesive, elbow grease, radiator, radiator brackets, hose clips, bonnet catches, nose cone grill, windscreen+fittings, wipers............
But then that's what building a kit is all about and most of it's not exoensive and largely down to personal choice/budget so don't be put off
I bought the starter kit and added bits along the way. I also made my own ally interior panels, which IMHO look better than the plastic ones (personal choice again). Having said that, the full kit is very good value and significantly cheaper than buying bits individually.
Order, build, drive...get on with it.
I may be able to help out on the donor package front as well if you're interested. U2U me for details.
Nick
posted on 30/1/06 at 12:51 PM Reply With Quote
Ed, for your £2,495 you will also get the following in addition to the list above
Interior Panels - Full set
Full Brake pipe set
Exchange steering rack
Battery tray
Engine mounts
Oh yeah and the shocks are the lighter, aluminium Protech jobbies. Not sure if you get the balljoints or the rack extensions though......
DarrenW
posted on 30/1/06 at 01:20 PM Reply With Quote
Why have mutton though when you could have Fillet steak. For similar money you could join the exclusive Mac#1 club.
TimC
posted on 30/1/06 at 01:28 PM Reply With Quote
Wahey - Penis size comparisons here we come!
ned
posted on 30/1/06 at 01:53 PM Reply With Quote
mines home made - its a small one
ps sorry for the hijack ed
beware, I've got yellow skin
posted on 30/1/06 at 02:50 PM Reply With Quote
........... and have the mutton
DarrenW
posted on 30/1/06 at 04:08 PM Reply With Quote
You are getting slow Mr. Hellfire. That took you 90 mins to post a reply this time
(Did you like the Mr bit??? thought id display some manners seeing as im in your house!!)
ned
posted on 30/1/06 at 05:06 PM Reply With Quote
OOOPPPSS I MAY HAVE TRUMP'D
someone been deleting posts i wonder?
hmm
Jon Ison
posted on 30/1/06 at 05:47 PM Reply With Quote
Originally posted by CaLviNx
Hi
For the price of £2295.00 you get :
# Kit includes Chassis
# Roll over hoop
# Headlamp brackets
# Floor
# Seat back bulkhead
# 2 x top wishbones – made using oval section tubing. To accept GTS rapid camber adjusters
# 2 x camber adjuster
# 2 x lower wishbones – made using oval section tubing
# 4 x trailing arms
# 4 x GTS adjustable shocks with springs.
# De-dion axle – to accept either drums or disc brakes.
# Panhard rod
# Panhard rod, rod end
# Poly bush set
# 2 x top ball joints
# 2 x lower ball joints
# 10 piece GRP body work set – includes back panel, side panels, nose, bonnet, scuttle, rear wings and front cycle wings. Your choice of over 70 colours.
# 2 x steering rack extensions
# 2 x Sierra front upright inserts
# Suspension nut, bolt and washer set
# Front cycle wing supports
# Exchange Sierra front uprights
# Adjustable pedal set
Deluxe Starter Kit - £2295.00 inc
This is from the excellent GTS tunning, who's quality is above reproach, but delivery times a little slow. but the wait is worth it for the quality. (rock dwellers, please refrain from brain farting please)
Regards
Mark
ooooooo errrrrrr
mandbsheldon
posted on 30/1/06 at 06:37 PM Reply With Quote
Full Brake pipe set
Battery tray
Engine mounts
PLUS
Years of experiance
john_p_b
posted on 30/1/06 at 07:35 PM Reply With Quote
go for the MK over the GTS anyday, fair enough the guys at mk may not be the best when it comes to playing with a computer but they always helped me out when needed unlike the other company who just crawls under his very own rock and delivers as and when he feels like it.
built a car, built a home, had a family. lost the family, lost the home, still got the car.
mandbsheldon
posted on 30/1/06 at 07:37 PM Reply With Quote
john_p_b
posted on 30/1/06 at 08:14 PM Reply With Quote
just voicing my opinion leigh thats allnot trying to cause a war. calvin came on here basically trying to sway this guy away from buying a indy and to buy a gts instead but imo the mk would be better to go for as it has a far better back up.
andyace
posted on 30/1/06 at 09:07 PM Reply With Quote
My GTS kit also came with interior transmission tunnel ali panels and pinto engine mounts, not sure if std but these items mentioned in W7DE kit as well
[Edited on 30/1/06 by andyace]
Triton
posted on 30/1/06 at 10:45 PM Reply With Quote
swings and roundabouts and not really much point starting a war over it.....They are all the same really at the end of the day.......Locosts with a few changes
www.tritonraceseats.com
www.hairyhedgehog.com
ed_crouch
posted on 30/1/06 at 11:43 PM Reply With Quote
Snoopy,
Thanks for that: it has cleared a few things up.
When you say "remind them of it"...
Does that mean that some of the parts that were included in the kit no longer are?
This is not strictly a problem, just confused!!
Ed.
Hurrah.
zxrlocost
posted on 30/1/06 at 11:56 PM Reply With Quote
Ive had a recent MK kit
one thing you dont get anymore is a dahboard but you get the other interior panels
mandbsheldon
posted on 31/1/06 at 05:55 PM Reply With Quote
Bet ya don't get a badge with a GTS
Leigh
andyace
posted on 31/1/06 at 07:00 PM Reply With Quote
Leigh
You do actually get a badge !!
mandbsheldon
posted on 31/1/06 at 07:09 PM Reply With Quote
Not as big as a MK badge
mandbsheldon
posted on 31/1/06 at 07:24 PM Reply With Quote
If you would have used your head, you would have bought an MK. Now let that be the end of the matter
zxrlocost
posted on 31/1/06 at 08:11 PM Reply With Quote
christ ive heard it all now
mandbsheldon
posted on 31/1/06 at 08:13 PM Reply With Quote
<<  1    2  >>
New Topic New Reply
