New Topic New Reply
Author: Subject: headlight bar
zxrlocost
posted on 16/4/06 at 09:35 PM Reply With Quote
headlight bar
Ive fittend my headlight bar over the weekend in the correct place above suspension
lined it up and am using the 5 and 3/4 inch carbon fibre lights from SVC
problem is theres hardly any gap inbetween the light and nosecone probably a few mm
is this right
ta chris
CairB
posted on 17/4/06 at 10:03 AM Reply With Quote
Originally posted by snoopy
best picture i could find
Chris,
The headlight bar shown is not standard MK so it may not be relevant (not obvious though snoopy). I made it from 1" section with 2 pieces of 25x3mm flat welded top and bottom and clamped to the chassis rail by an M8 on the inside.
It was in the early days and I was after a way of doing it that mean't that the nosecone didn't need modifying. The 3mm thickness on the top gets taken up with the fiberglass side panel.
BTW I've since removed the duck tape so it fires on all 4 and the lawn mower is still going strong
Colin
[Edited on 17/4/06 by CairB]
zxrlocost
posted on 17/4/06 at 05:58 PM Reply With Quote
thanks for the pics but my headlight bar is loads shorter apparently its a new design
john_p_b
posted on 17/4/06 at 06:04 PM Reply With Quote
can't you fit it further forward?
built a car, built a home, had a family. lost the family, lost the home, still got the car.
zxrlocost
posted on 18/4/06 at 08:43 AM Reply With Quote
no mate because it already has the hols which line up with the chassis
I know I could drill others but it still looks ok
so ill see how it goes
john_p_b
posted on 18/4/06 at 07:56 PM Reply With Quote
didn't realise they came pre drilled, i had to guess my own when i built mine, think mine sits slightly in front of the suspension
New Topic New Reply
