New Topic New Reply
Author: Subject: WHAT DIF SHOULD I USE
OX
posted on 13/6/03 at 12:45 PM Reply With Quote
hello to every one
well iv just orderd my mk indy car and am now doing abit of shopping around but would like a bit of info as what dif i should be useing,i would like a limited slip dif and have found one off a xr4i ,will this be any good . im sure this isnt the only question i will be asking as this is my first project but i will try to find most of the answers on the forum to save wasting anybodies time
ned
posted on 13/6/03 at 12:55 PM Reply With Quote
the xr4x4 dif is the one to go for, if you want/need an LSD, otherwise a standard sierra dif will do (there are various ratios, a post under running gear today i think should explain.
otherwise search the forum, there are lots of informative old posts/threads out there.
Ned.
beware, I've got yellow skin
OX
posted on 13/6/03 at 05:10 PM Reply With Quote
thanks for the reply,im picking one up on monday woohoo
MK9R
posted on 13/6/03 at 09:32 PM Reply With Quote
Bear in mind that the diffs vary in size (width), so you will have to make sure you get a diff that is correct for the chassis you ordered. I think the majority of diffs are 7" fitment, and unless you stated you were using a particular difff (eg Cosworth) then you should be.
Cheers Austen
RGB car number 9
www.austengreenway.co.uk
www.trackace.co.uk
OX
posted on 14/6/03 at 08:20 PM Reply With Quote
ok the bloke who im buying the lsd off wants to sell me the whole rear end from wheel to wheel for £150 is this a good price,it seems ok to me, every thing seems cheap compared to motor bike bits woohoo,engine's gonna be the most expensive part after the chassis but there you go again a damn motor bike bit
greggors84
posted on 15/6/03 at 01:51 PM Reply With Quote
Is the LSD rearr diff the same size as the standard sierra one?
Im just thinking if it will fit straight into the indy.
New Topic New Reply
