LBMEFM
posted on 10/5/07 at 08:54 PM |
Rear Disc Calipers
Do you have to fix the flexi hose on a bracket where it joins onto the small brake pipe from the caliper. If so where do you mount the bracket?
Regards
Barry
mackei23b
posted on 10/5/07 at 09:05 PM |
Hi there
Rear flexi should go straight to the caliper.
Ian
LBMEFM
posted on 10/5/07 at 09:10 PM |
Rear calipers
Hi Ian
Thanks for the advice, however, MK supplied me with copper pipes, one longer than the other for the rear calipers, do I not need these then.
Barry
ReMan
posted on 10/5/07 at 09:30 PM |
Think you'll find they're for drum setup.
snoopy
posted on 11/5/07 at 06:51 AM |
the brake kit supplied fits both the drum setup uses the two small brakepipes about 4 inch long the disk setup doesnt need these as flexi,s fit
straight to calipers
LBMEFM
posted on 14/5/07 at 09:16 PM |
Rear disc calipers
Hi Lads
Once again thanks for the help
Barry
