benfred
| posted on 26/6/07 at 05:21 PM |
Alfa 75 as donor car for a MK-Indy!?
A friend of mine wants to use a Alfa 75 as donor car or only the engine and transmision for a MK-Indy. Is there someone who already did (tried) this.
Sorry for my bad english and thank you for taking some time to read and hopefully answer this post. Greetings, Ben. The Netherlands.
theconrodkid
| posted on 26/6/07 at 06:17 PM |
the gearbox is a transaxle so no good for a 7 type car,like all (most) alfa,s tho the engine is a peach,someone on here mated a V6 alfa to a type 9 i
believe?
who cares who wins
pass the pork pies
jacko
| posted on 26/6/07 at 06:42 PM |
believe?
Trev Borg is the man with a v6
Jacko
benfred
posted on 26/6/07 at 07:23 PM |
Alfa 75
Hello Conrodkid, can you explain to me why the transaxle is no good for a 7? The weight of the gearbox at the end of the car should be an advantage!
Ben
owelly
| posted on 26/6/07 at 07:36 PM |
The weight is a good thing. The space to put the transaxle means that the occupants have to sit under the bonnet or up in the sky above the gearbox!
Thats no so good.
However....
And don't discount the Twink engine either!
http://www.ppcmag.co.uk
sebastiaan
| posted on 26/6/07 at 08:19 PM |
It's this big...
whitestu
| posted on 26/6/07 at 08:29 PM |
I love Alfas and the twin spark is a good motor, however is it worth the effort compared to a Zetec?
Stu
StevieB
| posted on 26/6/07 at 08:48 PM |
Stu
If only just for the noise it makes!
martyn_16v
| posted on 26/6/07 at 09:27 PM |
... if you have shares in an oil company. Of course, i'm sure they're not all as bad as mine
Marcus
| posted on 27/6/07 at 11:20 AM |
Hmm, mine uses about a litre every 1000 miles!! (2l twin spark)
Marcus
Because kits are for girls!!
owelly
| posted on 27/6/07 at 09:52 PM |
My 2ltr 156ts has only glugged about 500mls in the past 5000 miles. Which is very odd considering it leaves a oily patch wherever it's parked. I
could fix the sump joint but then I'd forget to check the oil.....
benfred
| posted on 27/6/07 at 10:56 PM |
thanks for the respons!
My friend is sure that he can do it. He wants to rebuild the MK-chassis to fit the Alfa rear axle and gearbox. He is the owner of a car repear shop
and has all the stuff to build or rebuild a car. That makes things easier. There will be a website to show the progress. See you then. it is shown on:
www.benvn.nl. Regards Ben
