graememk
| posted on 2/9/07 at 09:40 PM |
MK Indy tracking
going to get my tracking done tomorrow as its still toe out from sva as i've been lazy to change it.
what do you think ? 1deg toe in ok ?
[Edited on 2/9/07 by graememk]
bigrich
| posted on 2/9/07 at 09:59 PM |
i would say 1 degree as a maximum, any more and they get a bit twitchy IMHO somewhere in the 0.5 to 1.0 toe in region should work ok and around the
same in negative camber all round also is a good starting point.
worX
| posted on 2/9/07 at 10:18 PM |
Ride height set to 100mm front 120mm rear
0.4 - 0.75 degree toe in front
0.25 - 0.5 degree toe in rear
1 degree negative camber front
0.5 degree negative camber rear
18psi tyre pressures
those should do you for a start point.
cheers,
| posted on 3/9/07 at 07:55 AM |
Whilst I wouldn't disagree with most of these figures (our fronts are parallel), in my opinion tyre pressures of 18psi is too high (for a BEC -
if yours is CEC then sounds ok). 14-16psi is more suitable for typical road driving, drag-days lower still.
cheers,
[Edited on 3-9-07 by Hellfire]
