StevenB
posted on 12/3/08 at 09:37 AM |
Wheels to suit MK
Can someone offer a few suggestions here.
I am looking to use 15" x 6.5 with 195x50x15 with an ET of 42.
I have asked for Fox R2 & FX2, OZ ultra leggera, Wolfrace Ikon Plus with no joy.
When asked what wheels were available in 4x108 - ET42 they said it doesnt work like that and I had to pick a wheel first.
posted on 12/3/08 at 09:41 AM |
ok, then pick all of them.
Kriss
posted on 12/3/08 at 10:07 AM |
many websites let you selected your PCD, ET etc and then chuck a whole list of available wheels at you.
wheelbase i think does
StevenB
posted on 12/3/08 at 10:42 AM |
Im using standard wheel arches and rear discs.
What ET range can I work in?
Or is 42 the limit?
s
TimC
posted on 12/3/08 at 10:50 AM |
Chenge who you're buying the wheel from... sound like monkeys to me.
philw
posted on 12/3/08 at 10:54 AM |
I have a set of ultraleggera with pcd 108 and 42 offset almost new about 1k miles use shod with Toyo t1s 195 50 15 i maybe tempted to part with them
ReMan
posted on 12/3/08 at 12:47 PM |
Seconded.
It's tru that every wheel is not available in every offset, but they're not exactly being helpful are they?
PAUL FISHER
posted on 12/3/08 at 02:07 PM |
You have a few options with original Indy chassis,the new chassis by the way excepts a much larger range of offsets "ET"
The best option in my opnion is a 7" wide rims, ET 35 or 38 these 7" wide rims are more common to the performance range of wheels,team
dynamic's,OZ,and Compomotive.
StevenB
posted on 12/3/08 at 07:54 PM |
Paul,
I thought the ET for the standard sierra wheel was 38. So going up to widths of 6.5 and 7" would take the ET up as well?
s
PAUL FISHER
posted on 12/3/08 at 09:24 PM |
Yes Steve you are correct,the et 38 7" will stick out another 10mm,but the Indy will take a wider wheel with no arch fouling problems,so long
as you dont go for tyres over 205 wide,195's are more usual,you will have no problems with a 7" et 38,it just fills the arch better,and
gives you a bigger choice of wheels,due to it being a standard sierra upgrade size.
quote: Originally posted by StevenB
Paul,
s
PAUL FISHER
Paul,
s
