New Topic New Reply
Author: Subject: zx12 mounting points?
eznfrank
posted on 15/3/08 at 08:14 PM Reply With Quote
can anyone point me in the direction of some good photos of the mountings for zx12 in an indy. I've tried the usual places but can't see any properly. I think my mounts might be wrong!
Unfortunately I can't upload pictures for some reason but there all in my photobucket album here
Have i done something really stupid? The engine is bolted in place on the offside (drivers) but the bracket from MK is about 2 inches out on the nearside(passenger). As far as I can see it would be impossible to bolt the O/S anywhere else!?!?!
[Edited on 19/3/08 by eznfrank]
posted on 15/3/08 at 09:13 PM Reply With Quote
There are two different mounting locations for the ZX12R depending on year of engine. Our engine is 2004 and has a single mount at the front, which can be seen in the lower picture.
The picture below shows the engines rear upper mountings. Lower mountings are also just visible. There may also be a few more pictures on our website.
Phil
eznfrank
posted on 15/3/08 at 09:48 PM Reply With Quote
Cheers mate, your site was actually one of the "usual places" I was referring to. Mine is an 01 motor so not sure if that's why mines different. I'm convinced it's wrong!! May have to post some photos
posted on 15/3/08 at 09:54 PM Reply With Quote
Did MK have your engine for locating the mounts when they built your chassis? What is actually wrong, does your engine not fit?
Phil
eznfrank
posted on 15/3/08 at 10:07 PM Reply With Quote
No I just told them to buid it to take a ZX12R motor but didn't specify a year as I didn't have the motor at the time. The block I have is an '01 although it was out of an '04 bike (just to complicate things). I just checked my O/S mounts and they are actually the same as yours. However on the N/S 2 points on the top rail with a seperate piece bar that I figure must attach somehow.
eccsmk
posted on 16/3/08 at 08:57 AM Reply With Quote
on the exhaust side of the engine mk added two lugs to my chassis and the made b bracket to accomodate all models of zx12
i threw this away and used the origional from the bike will post a pic shortly
eccsmk
posted on 16/3/08 at 09:30 AM Reply With Quote
eznfrank
posted on 16/3/08 at 11:06 AM Reply With Quote
Thanks mate, is yours a later model block too?? I think I figured mine out now although I think the extra bracket they gave me may need spacing from the chassis??
eccsmk
posted on 16/3/08 at 12:25 PM Reply With Quote
from what ive been told (thank you mr hellfire) the later models have the two mounting points in the middle of the head head between the two centre exhaust ports (like mine) and the earlier models use the two very outer points as in the piccy
mine was a real pig to line up with the mk mount hence i used it as a paper weight lol
also ive used those two ugly brackets to hold my heat shield on
[Edited on 16/3/08 by eccsmk]
eddbaz
posted on 17/3/08 at 06:27 PM Reply With Quote
mk have built a cradle and welded mounting points for my 2000 zx12r on my chassis I'll post some photos tomorrow,the 2000 engine has the same mountings as a 2001.
eznfrank
posted on 21/3/08 at 08:17 AM Reply With Quote
Big thanks to Eddbaz who hooked me up with some photos of how my bracket should look. (which fortunately looks very similar to the template I made!!
New Topic New Reply
