Staple balls
posted on 28/11/03 at 01:28 PM |
mk brake pipe kit
is the mk brake set thingy any good? and would i still be needing a pipe flarerer and whatever if i got it?
cheers
alex
posted on 28/11/03 at 06:28 PM |
MK Brake Kit
We bought the said Kit and yes it is good - depends also where and what you're going to mount your flexi's to.
Have a gander in our website and see what we had to do with it... oh and yes we had a flanger.
Staple balls
posted on 28/11/03 at 06:35 PM |
thanks, i'd already had a looksee at your site
locoboy
posted on 28/11/03 at 09:05 PM |
cant beat a good bit of flanging late in the wee hours of the morning eh Hellfire
Locoboy
posted on 29/11/03 at 01:24 AM |
Flanging...
can't beat a good bit of flanging Col... one word of warning - when you hand make the tool it's best if you anneal the copper pipe first
as the bell end gets a bit stiff after a while. Best to use a bit of vaseline to get it well lubed up - then it easier to pull the flange from the
bell end after you've done the dirty... if you get my drift?
Course if it's a male flange you obviously have to do it a second time to get the bullnose to form the flange back in again... HEHE!!!
locoboy
posted on 1/12/03 at 04:54 PM |
too true
Locoboy
Mk-Ninja
posted on 1/12/03 at 06:34 PM |
Ive just fitted the brake pipes to my indy, without having change or flange anything.
I dont know if I should be pleased or not, sounds like Im missing out.
Gordon
I'm sure I've got one, just don't know where I've put it
MK7
posted on 2/12/03 at 09:10 PM |
My 2 cents
I bought the MK kit and found it most challenging to work out a route that would allow the pipes to end in the right places for the flexies to fit. I
must have had them in and out 3 or 4 times and on each ocassion there is a risk of damaging the pipe.
Eventually I got them in but I'm convinced they're not in the place they are supposed to be.
I made the decision that if I was going to do this again I'd buy all the bits and a decent flanging tool and do it all myself. I really
don't see the benefit in buying the pipes ready assembled.
Russell
Staple balls
posted on 2/12/03 at 09:23 PM |
yeah, i'd seen a few things like that about the Mk kit, and seeing as a local car shop were doing 25' of brake pipe for £8, i decided
it'd work out better to sort it myself
posted on 3/12/03 at 12:30 PM |
Russell
Having bought the kit, fitted it, took some of it out and bought some more pipe to route it the way we wanted, I would tend to agree with you Russ.
Thing is though..... when you're a bit green to brake pipe fitting, it seems like a potential minefield. Like all things, once you understand
how it all fits together and have a practice it really is quite simple.
posted on 3/12/03 at 03:42 PM |
I'm swapping my flaring tool, flanging sounds so much better. Actually I was looking for a flanger earlier but it's a guitar effect,
nothing to do with brakes.
yours, Pete.
MK7
posted on 3/12/03 at 11:49 PM |
Thanks Pete :-)
But the sentiment remains. I bought the MK kit cos I was green.
Several times during the assembly process I became red
Having been through the process only once, in my books it's once too often.
Having said that I've never used either a flanging kit or a flaring kit so I could be talking complete bovine feces...
...but somehow I doubt it, I mean, how difficult can it be to flare a copper pipe with the right tool?
Russell
