ReMan
| posted on 16/11/08 at 09:43 AM |
Mine was OK with the fog light mounted on a bit of bendy ally same place as yours.
AI also did the smae with the exhast and it did'nt get a mention.
Car looks great BTW
bob
| posted on 16/11/08 at 02:58 PM |
Hi matt
Hard to tell from the picture.
Are those rear reflectors raised on the edges ? mine failed on radius edge with contact of the sphere, i ended up moving them inbetween rear cluster
and back panel to avoid the sphere.
If they are raised edges it looks a bit tight to move them so maybe a bit of silicone round them would do the trick.
flak monkey
| posted on 16/11/08 at 03:43 PM |
Looking good Matt! Good luck on friday, I'll keep everything crossed for you!
Take as many tools as you can, just in case!
Sera
http://www.motosera.com
RK
| posted on 16/11/08 at 04:59 PM |
Beautiful job! Good luck with your test!
jabbahutt
| posted on 17/11/08 at 07:58 AM |
Really tidy job, looks the business. Two things that iu can't see from the photographs.
1. ther chassis rail that crosses the passenger and driver compartment about where your shins are needs padding incase of a collision.
2. the return edges of the scuttle inside need trimming.
Oh and if you've used tape on the ball joints it'll fail, replace with tie wraps with the sharp bit to the back.
And the tie rod extension needs covering, I used bike inner tube and tie wraps.
Good luck with the test.
Nigel
flak monkey
| posted on 17/11/08 at 08:32 AM |
The tape you can see is self amalgamating tape, not insulating tape, so it should be ok, as it cant be removed without cutting.
Sera
matt.c
| posted on 18/11/08 at 07:37 PM |
Sorted the fuel cap and have had a look at the seat belts. Trouble is now i have found a water leak!!
[img][/img]
jabbahutt
| posted on 20/11/08 at 07:59 AM |
good luck for Friday
matt.c
| posted on 20/11/08 at 09:12 PM |
11 hours till the SVA!!!!!
DavidW
| posted on 20/11/08 at 09:21 PM |
Good luck!
matt.c
| posted on 21/11/08 at 02:28 PM |
Woohoo i failed lol
passed everything apart from a couple of brake unions not fitting right so all went really well.
Got bloody wet and the car covered in muck but all worth it!!
welderman
| posted on 21/11/08 at 02:34 PM |
UNLUCKY Matt but sounds like a not so bad fail, get it booked in for MOnday.
Thank's, Joe
I don't stalk people
flak monkey
| posted on 21/11/08 at 03:05 PM |
Get it sorted and retested within a week and its free too
A good fail that mate! Told you everything would be ok First impressions make all the difference!
Sera
jabbahutt
| posted on 21/11/08 at 03:23 PM |
Well as fails go that sounds like a really good one. How long do you reckon to sort out the union problem and what exactly was the problem?
Nigel
locoR1
| posted on 21/11/08 at 04:20 PM |
Well done Matt that's a relay good fail nice and easy to fix, shouldn't be long now
Check out my CB500T Cafe Racer build diary
adithorp
| posted on 22/11/08 at 10:49 PM |
Hard luck but thats not a big list .
You've got to be happy they find a brake problem before it finds you and you end up in a ditch or worse.
adrian
http://jpsc.org.uk/forum/
