grazzledazzle
posted on 1/5/09 at 08:34 AM |
quote: Originally posted by grazzledazzle
Mondeo St200 2.5 V6.
202bhp as standard with all the restrictive ford stuff on it.
So a 2.5 l engine is less than 2.0 l then?
I made that mistake too.
No, i'm, just ignoring that restriction as it seems the limiting factor on a budget.
posted on 1/5/09 at 08:59 AM |
231 version of the RX8. Tiny motor and the 6-speed gearbox will fit most 7's.
You can normally haggle breakers down to the £1500-£2000 mark for engine, box and ancillaries.
Only problem is the Oil Metering Pump. The Mazda ECU controls it, but you will have to junk the Mazda ECU to get the engine to run outside of its
normal application.
When I last looked (about 18 months ago), there were no aftermarket ECU's that could support a rising-rate OMP.
There were a few plane-engine builders using the RX8 and they had made OMP's, but I never fully explored that option.
The other solution is to just pre-mix your fuel with some oil... bit of a PITA though!
minitici
posted on 1/5/09 at 09:40 AM |
SBD do some awesome engines
SBD
bimbleuk
posted on 1/5/09 at 09:42 AM |
To me the obvious choice is the Honda K20A which is 197BHP in production format. Easy gains just from induction and exhaust mods. Probably the most
reliable of all the engines mentioned so far surely?
Cost depends on how much you will be fabricating and how good you are with modern wiring/electronics I suppose.
posted on 1/5/09 at 10:31 AM |
That's fine as long as the scrutineers take the same attitude
I think the Duratec is the obvious choice if you aren't keen on the 20XE. The S2000 engine is ok, but fetch a very large premium and are
physically large engines.
[Edited on 1/5/09 by MikeRJ]
posted on 1/5/09 at 11:18 AM |
Can't believe nobody has asked you what your budget is yet. The answer to this question will determine which engine options are available.
So...... what's your budget?
Phil
posted on 1/5/09 at 11:38 AM |
Would depend on the equivalence factor applied to rotary engines by whatever body regulates the race series the OP runs in! Is quite likely not
considered under 2.0L.
Phil
It's a very good point, if the budget is large enough I'll suggest a
Millington Diamond or for really good sized budgets a, RST-V8.
Humbug
posted on 1/5/09 at 11:40 AM |
quote: Originally posted by Hector.Brocklebank
quote: Originally posted by BenB
Sounds like a bike engine to me
EXcept they don't make 'em 2L big!!
erm.... 2300cc engined PRODUCTION motorcycle
[Edited on 1/5/09 by Hector.Brocklebank]
...except that it has worse performance than a car engine!
"147 ft.-lbs. of torque at 2,500 RPM and 140HP at 5,750 RPM"
grassracer
posted on 1/5/09 at 11:50 AM |
Budget is £1000-£1500ish, flexible if the right package was available!! Over 2.0 is allowable but must be 2 valves per cylinder sorry I didn't
make that very clear
stevebubs
posted on 1/5/09 at 12:10 PM |
surely it can't be that hard to get 200bhp out of a Rover V8???
What capacity limit for 2v engines?
posted on 1/5/09 at 12:33 PM |
Except the full quote was
"Ouch!! 100Bhp/litre NA.....
EXcept they don't make 'em 2L big!! "
That's just a car engine in a bike. Ain't anything near 100Bhp/litre
posted on 1/5/09 at 01:05 PM |
RST-V8 is the closest thing, pretty much two bike engines mounted in a V (that said only bike cylinder heads are actually used, the cylinder
block/crack case is bespoke).
Hector.Brocklebank
posted on 1/5/09 at 01:13 PM |
Have you seen the weight / power figures of the Rocket though? Bit dissapointing.
have a look at this version in no way standard, but shows what can be done with this engine, has been heavily modified for more power too
Roger Allmond's Triumph Rocket
III special
clairetoo
posted on 1/5/09 at 03:14 PM |
III special
That looks awesome
Its cuz I is blond , innit
Claire xx
Will weld for food......
Jenko
posted on 1/5/09 at 03:33 PM |
I've just about managed 200bhp with my ZVH engine (but not on that budget).....8v, Ferriday bottom end (£1300)...Ported head £350, kentCVH27 cam
kit (£290)..and fuel injection with GSXR TB's......
But, If I'm honest, it was more luck than judgement...I was expecting more like 170-180bhp.......
MY BLOG - http://westfieldv8.blogspot.co.uk/
posted on 1/5/09 at 03:39 PM |
III special
Bike looks awesome, but couldn't see any engine- specs on the linked site or what engine work (if any) had been done.
Sure, it's got great torque figures straight out of the box (for a bike engine), but the engine weighs the same as many car-engines which
produce just as much torque, but a good bit more BHP than the 120 of the Rocket III.
MikeR
posted on 1/5/09 at 03:59 PM |
One good thing about engines that have been "done to death" - so has all the costly development and mistakes!
mad_dogpompey
posted on 1/5/09 at 06:30 PM |
duratec 2000cc is good for 200 brake with cam and throttle bodies with a 6500 rpm red line but judging by my mates experience i wouldn t strip the
engine unless you really know what your doing!!!!
Dave Ashurst
posted on 1/5/09 at 07:26 PM |
the racing trucks use the 4 speed rocket box with 230bhp, not sure if they're any stonger as standard, but they're the same length and
bolt patterns. they might be quaife boxes though
I've got a nice quaife 4 speed rocket box - HEAVY DUTY model, synchro, square cut, close ratio gearset, 2.04 1st, alloy cover.
Could sell . . . . .
jpindy3
posted on 1/5/09 at 07:29 PM |
pinto
turbo pinto,std pinto second hand turbo all the bits 600quid ,you can run 12psi boost that means 200bhp ,you can get more but you might do a pisto or
two,thay have been known to handle 18psi ,"by the way this is on std internals"
turbo pinto power
ps look at tourbosport furom,look in pinto xflow bda
just read your post no turbos doh,
red top my mates got one in his super stock!had it on the rollers today 212bhp@the fly175 @wheels
[Edited on 1/5/09 by jpindy3]
flak monkey
posted on 1/5/09 at 07:31 PM |
turbo pinto power
They'll handle that for a few miles, but not for long. Reliably the max is 8psi on stock internals. Forged low comp pistons would let you run
18-20 reliably.
Sera
http://www.motosera.com
jpindy3
posted on 1/5/09 at 07:39 PM |
turbo pinto power
18-20 reliably.
ok im just going on what a somone in sweeden has said is pos "therealpinto is his name on turbosport furom"i think thay will take 12psi
fine,il just have to wait to find out,got my 202 pinto today
expatkiwi
posted on 1/5/09 at 09:09 PM |
I run a 13b bridgeport rotary engine in my westy(well I will when its finished) Butbthe engine cme from my 1st gen RX7. Its N/A and has about 230
bhp.
The rotary equivilance for sprints and hillclimbs is 1.5 sooooooooo 1308ccx1.5=1962cc ish Now lets not get into any argumants etc about swept volume
blah blah blah but I have been very succesfull with the old rx over the past 3-4 years that the desision was taken to do this as I wanted to beat all
of the piston powered 7s not just a few of the..sorry I digress
Pics
http://i156.photobucket.com/albums/t21/kiwimazda/IMG_2099.jpg
http://i156.photobucket.com/albums/t21/kiwimazda/IMG_2098.jpg
I have decided to call my Westfeild "The Caterhammer" Hopefully it will
Jasper
posted on 2/5/09 at 06:17 PM |
Don't know why you don't go turbo, 200bhp any other way is gonna cost you thousands, that would be straight out of the box for an £800
SR20DET engine, and even the cheapest mods would get that to 250bhp for about £400.....
Mine will be around 280-300bhp for about £2k total ...
