<<  1    2  >>
New Topic New Reply
Author: Subject: SVA date
bob
posted on 6/5/04 at 07:54 PM Reply With Quote
FAIL
But if a fail can be a good one,i got it
All the important stuff passed no probs,brakes electrics speedo emisions.
Its the radius stuff that gets you.
One small part of dash eg two clocks
another small part of handbrake lever
boot lid edge and key locks
Part of top wishbone that i thought was non contactable,plus on the front damper adjuster knob and a small part of cycle wing strut.
rear reflector.
all the above are pretty easy to resolve and maybe i should have noticed them myself.
Last 3 fail points caught me out.
Seat belt upper anchorage,i thought the distance to base of seat was ok but i was an inch out. Mrs bob has offerd to buy me a pair of roadster 7's as an early birthday present so i'm happy
Nose cone indicators stalks,too short so anyone know of a good supplier ?
and the cheap black plastic headlights just wouldnt line up,no matter how much i fiddled and turned the glass.so i'm going to bash the credit card and buy some proper ones.
My examiner was was unfortunatly being examined himself,i thought this might make the whole test a nightmare but they were both top blokes and very fair.
My own problems with the car were as follows.
Stiff clutch
sticking throttle
broken front flexy for return home.
Big thanks to jason(deckman) for moral suport in the 1st hour and for the many messages of good luck on my phone.
Oh and mrs bob for putting up with me
All in all i think i got away with it
macspeedy
posted on 6/5/04 at 07:58 PM Reply With Quote
sorry to hear that as you said they are all small things and easily fixed, you'll be on the road in a week!
bob
posted on 6/5/04 at 08:02 PM Reply With Quote
cheers
forgot to mention pinking like mad.
Deckman001
posted on 6/5/04 at 08:07 PM Reply With Quote
seeing as you've allready passed the emisions bit, get the ignition looked at, ie: try to get it tuned, will make a difference i bet !! well done tho, all the major points were passed so nothing to worry about in the re-test
Thanks for letting me tag along as well, I'm getting to know the examiner now
Jason
Mark Allanson
posted on 6/5/04 at 08:13 PM Reply With Quote
How did you flexie break? Over energetic testing?
Sorry to hear about the fail, but it won't be long
Mark
posted on 6/5/04 at 09:10 PM Reply With Quote
nice one bob, alls well really. as said before, we need a pair of compliant headlights to share around. anyone got an idea on how we could make this work?
gjn200
posted on 6/5/04 at 09:19 PM Reply With Quote
How about a compliant car to pass around?
<- Me!
posted on 6/5/04 at 09:28 PM Reply With Quote
Sorry to hear of your oppurtunity to retest Bob. At the very least you have a tick list now .
Regarding the indicator stalks - we had to make our own but I'm sure I've seen some on VWP's site... headlights from SVC are "top banana" very good clear strong, "correct shape" beam and passed easy!
Surely next time! ATB
bob
posted on 6/5/04 at 09:30 PM Reply With Quote
I think i was just unlucky with the headlights,others have gotten through with them.
The examiner being wathced by the examiner didnt help
I think the flexy took a beating when the examiner was doing the self centreing,he had it on full lock to start which on an indy is slightly more than the average london black cab.
I'll refit new flexy's and reduce the lock
[Edited on 6/5/04 by bob]
scotlad
Contributor
Posts 781
Registered 30/9/03
Location Edinburgh
Member Is Offline
Photo Archive Go!
Building: Built MK Indy Blade, RH 2b Zetec, rebuilding locos
posted on 6/5/04 at 09:34 PM Reply With Quote
i lengthened my stalks with plastic conduit to pass the test. then errrr threw them in the shed and fitted nice wee m/bike ones!
posted on 6/5/04 at 09:51 PM Reply With Quote
well thats one idea... new engine and chassis plates every week, doing the country tour round all the test stations! im up for it... could sell the v5, chassis number and engine number as a job lot. £500? all good....
posted on 7/5/04 at 08:54 AM Reply With Quote
It would be interesting to see if it passed at every station, though I doubt it would. There'd still be some different interpretations from station to station.
alister667
posted on 7/5/04 at 05:26 PM Reply With Quote
I got some compliant length front indicator stalks from Stafford Vehicle Components. They're the 12cm stalk ones.
I think they look OK and my own SVA inspector had no worries with it.
They were 36 quid the pair.
http://members.lycos.co.uk/alister667/
bob
posted on 7/5/04 at 06:28 PM Reply With Quote
Thanks for that i'll have a go at stretching the ones i've got,when or if i've had enough and throw them down the garden i'll get onto SVC.
Marcus
posted on 8/5/04 at 09:56 AM Reply With Quote
Bob, seems you had a very similar test to ourselves a week earlier!!
Examiner being examined and all that!
Perhaps not quire as long a list as ours though.
You mentioned at Stoneleigh about reducing steering lock as mine failed on distorting flexis on full lock, assumed you had done this?
Indicator stalks - serves you right for having a wider track, ours were exactly 400mm from outside edge of car, so they JUST passed!
Best of luck with retest - haven't even looked at mine since fail!
Marcus
SteveO
posted on 9/5/04 at 07:52 AM Reply With Quote
Good luck on the retest, Bob. In a way safety is what its all about. The radius thing drove me a bit crazy as well and had to buy the new Mk nose cone that covers the top wishbone bracket as shown in the pic of the indicator.
bob
posted on 9/5/04 at 10:15 PM Reply With Quote
Thanks steve.
I think i have the radius bits sorted except the clocks,i'll have to make some kind of pad and cover with vinyl.
Its just the headlights to buy now,unless i can get the same size lense in UK spec for the cheapo plaky ones.
alister667
posted on 10/5/04 at 07:00 PM Reply With Quote
I knocked up this to cover my clocks (fireblade clocks).
To describe it as truely hideous doesn't do it justice, but my SVA gimp thought it was OK.
I wouldn't be surprised if it fell off soon after the retest........ (this Wednesday).
I used vinyl and some foam backing for it. STuck it on with silicon sealent. Should peel off OK.....
bob
posted on 10/5/04 at 08:29 PM Reply With Quote
More or less what i had planned,cheers for that.
posted on 11/5/04 at 11:15 AM Reply With Quote
Good Luck for tomorrow Alister
<<  1    2  >>
New Topic New Reply
