New Topic New Reply
Author: Subject: Track and camber for Indt
david cromie
posted on 21/1/04 at 12:51 AM Reply With Quote
Can the brains out there tell me thetrack and camber for the Indy, fromt and rear please. what is the best way to secure the cycle guards , can they be stuck and is it safe or is the old bolts still the best?david
zetec
posted on 21/1/04 at 06:56 AM Reply With Quote
Front needs to have as much castor as poss so get them hubs leaning back as much as possible. You will need to "toe out" the steering to get it to self centre, then after SVA you can return it to near straight for road use. I seem the remember MK quoting 0% camber front and back. Don't worry too much about the way the car drives with settings for SVA, it feels crap, but is fine after settings are returned to normal. Also start with soft settings on shocks and work up or you will shake your self silly. I have stuck my front guards on. Attached with a thin bead of sikoflex first and once set built up the joint, no problems so far, still as solid as when first installed.
DEAN C.
posted on 25/1/04 at 07:36 PM Reply With Quote
Hi Zetec,
When you just stuck your fronts on did you extend the steel bar to go all the way across underneath? I'm just about to do mine, if yours hav'nt fell off I think I try the same. I'll be using Wurth panel sealer which is just the same.
DEAN....................
Once I've finished a project why do I start another?
zetec
posted on 25/1/04 at 10:28 PM Reply With Quote
I just used the standard support. Bent it so it followed the shape of the guard as best I could, then just slapped it on.
david cromie
posted on 27/1/04 at 11:42 PM Reply With Quote
Guards, stick or bolt.
Ref. guard stays I lengthened the stays to go across the inside of guard by welding a wider bar on top which will give a bigger area for the siloflex to grip. Tks for all replys. david
New Topic New Reply
