New Topic New Reply
Author: Subject: How many rivets
Jonte
posted on 22/1/04 at 10:49 AM Reply With Quote
How many rivets
Kind of a stupid question
But I´m trying to prepare for my Indy arrival, so I just wonder how many ali-rivets I need for the floorsections.
I don´t need the axact number, but take a guess
Click it
GO
posted on 22/1/04 at 11:04 AM Reply With Quote
just as a very rough estimate, say floor section is 6ft long total and 4ft wide.
If your gonna put the floor in in 2 separate peices then you've got a total length of 32ft, so depending how close you're gonna put your rivets, at 1 inch sep thats 384 rivets!
Mk-Ninja
posted on 22/1/04 at 11:49 AM Reply With Quote
Theres a thread a while ago on this, people seamed to vary between 300 and 500, I know it makes your arm hurt.
Gordon
I'm sure I've got one, just don't know where I've put it
Jonte
posted on 22/1/04 at 12:03 PM Reply With Quote
Gordon
OK...I tried to search at first, but couldn´t find that thread.
400...*ouch*
Click it
MautoK
posted on 22/1/04 at 01:30 PM Reply With Quote
I used 100 off 4.8mm large-head rivets for the floor (as supplied).
They are about 75-80 mm apart.
I laid a double bead of Loctite 5221 onto the chassis members (used about half a cartridge).
You have to be fairly quick because the sealant starts to cure within the hour.
My (borrowed) Pop Rivet gun exploded with 3 to go!
HTH.
donut
posted on 22/1/04 at 04:01 PM Reply With Quote
PLEASE buy the very best rivet gun you can afford. I'm on my 4th!! You would think i would have bought a decent one after the 1st collapsed!!! AND don't do what i id and leave a finger inbetween the handles. When the rivet goes it crushes your finger and bloomin well hurts!!
Now you know why i'm called a donut!!
Also buy loads of decent 5mm drill bits and 4.8mm rivets. I bought and used nearly a whole box of 500 from screwfix direct.
RoadkillUK
posted on 22/1/04 at 07:37 PM Reply With Quote
This is the best I could buy
One pull on the hair trigger and your rivet is done
I seem to have spent a lot of my locost money on tools, but it's been worth it, nothing worse that trying to do a job with the wrong tools.
Roadkill - Lee
www.bradford7.co.uk
Latest Picture (14 Sept 2014)
Jon Ison
posted on 22/1/04 at 07:40 PM Reply With Quote
Tool Tart
J/K
posted on 23/1/04 at 09:10 AM Reply With Quote
I like the look of that rivetter!
I still have a load of rivets to pop and that is far more appealing than sweating and swearing with the hand tool.
How much was it?
Nick
posted on 23/1/04 at 09:18 AM Reply With Quote
The tool itself is fairly cheap from Machine Mart
click here
but the expense is in the compressor, air lines, air lubricator, etc., etc.!
If you have a compressor though, just deduct the cost of a half-decent hand rivetter from this, and you'll see that it isn't a lot more.
I would have bought one if I'd had a compressor when I was rivetting - too late now...
rgds,
[Edited on 23/1/04 by David Jenkins]
bob
posted on 23/1/04 at 09:57 AM Reply With Quote
I thought martin supplied a BIG bag of rivets with the kit nowadays,maybe i was dreaming again.
Anyhow,i just ordered a multi pack(box) rivet selection from screwfix.com (£7.99 i think) and then got a pack of 500 most common size for around £5.
Donut is right about the gun,i'm breaking in my third although my 1st was not a cheap one and that still broke
Jonte
posted on 23/1/04 at 10:48 AM Reply With Quote
The kit contains rivnuts, but I thought that was different from rivets?
Can anyone tell me how it is?
Click it
Staple balls
posted on 23/1/04 at 08:37 PM Reply With Quote
ok, when i got my kit (mid november) i got a bag of rivets that was just enough to do the floor (80mm spacings) and some smaller, i assume for panels
RoadkillUK
posted on 23/1/04 at 09:02 PM Reply With Quote
How much was it?
Nick
The rivetter wasn't that expensive but the compressor was just over £200 from tesco.com.
We've also bought a sheet metal cutter, angled drill and many many more all useful of course.
Roadkill - Lee
www.bradford7.co.uk
Mk-Ninja
posted on 23/1/04 at 09:07 PM Reply With Quote
I can definitely reccomend an air riveter. It saves loads of time and effort, and there not that much more than a good quality hand gun. Have a look on Ebay, mine was less than £30.
Gordon
New Topic New Reply
