FASTdan
| posted on 9/12/08 at 12:39 PM |
sierra based speedo cable route
Having installed the speedo cable in our indy last night I notice that it needs a sharp 90deg bend as it comes out of the side of the gearbox due to
the drivers side footwell wall/box section.
Does the cable function ok with such a bend in it? This is obviously something I wont be able to sample until we're ready to test drive.
There doesnt seem an easy way of aleviating such a bend without having the cable coming in through the footwell (wouldnt look nice) or modifying the
footwell panel.
whitestu
| posted on 9/12/08 at 12:47 PM |
Its a squeeze, but mine worked fine like that.
The hardest bit is getting the circlip in that holds the cable in the gearbox.
Stu
mcerd1
| posted on 9/12/08 at 12:56 PM |
In a word - No
if its too tight you need one of these:
http://www.speedycables.co.uk/
I guess it comes down to: how tight is too tight ?
but the tighter you bend it - the shorter its life will be.....
[Edited on 9/12/08 by mcerd1]
jacko
| posted on 9/12/08 at 01:00 PM |
Hi mine works fine like that 4 1/2 years
the only thing i have done is made a dished cover in line with the drive coming out the gear box
you don't need to buy a 90% drive if you do this
Jacko
Bluemoon
| posted on 9/12/08 at 01:01 PM |
As above but my approach is (not driven yet!):
You need a new cable for the 90 drive, thus you might as well use the old cable till it snaps..
To avoid it snapping, attempt to make the bend radius as large as possible..
Some people have run the cable under a carpet/rubber matt so you can avoid the bend (the cable then gently bends back up to the scuttle)..
Dan
Bluemoon
| posted on 9/12/08 at 01:03 PM |
Hi Jacko,
any photos?
Dan
jacko
| posted on 9/12/08 at 02:14 PM |
Hi its a bit hard to see you can just see the bulge on the side off the tunnel wall
  Dash/3
Jacko
whitestu
| posted on 9/12/08 at 03:05 PM |
Once it is in the bend isn't that bad. Personally I wouldn't bother with the 90 degree unit.
Will you be sticking with a cable driven speedo? I ditched mine in favour of an electronic so no need for a cable.
Stu
[Edited on 9/12/08 by whitestu]
FASTdan
| posted on 9/12/08 at 03:12 PM |
Stu
possibly not, we're doing the usual build it with the stock sierra stuff, get it SVA'd then stick all the aftermarket stuff on.
If it is simply a case of shortened service life I think I'll leave it be as it'll no doubt be ditched in the future anyway.
Does anyone know the internal circlip size? ive got a 25mm (bore) to try but roughly measuring with verniers it looked more like 26?
Stuart_B
| posted on 9/12/08 at 05:06 PM |
i am using a stock serria cable in a mk, it is tight but it works.
i think the circlip is 28mm if i rember right. i think burton sell them single.
stuart
FASTdan
| posted on 9/12/08 at 09:05 PM |
stuart
Is that 28mm circlip size or bore size? ie for a 26mm bore you need a 27.9mm clip (which tallies with what you are saying) but the classification is
based on the bore it is to be used in.
mcerd1
| posted on 10/12/08 at 08:57 AM |
linky
