matt.c
posted on 3/1/09 at 05:52 PM |
TOWING EYES FOR THE INDY
Thinking of putting some towing eyes ie the red ones use in racing cars on the indy (front and back). Whats the best way of fixing them the the
chassis? The front should not be much of a problem as the crossmember at the front is perfect. The rear is not so easy.
Which side on the rear and front should i have them? Left or right side?
Thanks locosters
mad-butcher
posted on 3/1/09 at 06:22 PM |
If it was me I would be very careful as it's only 16g box and unless you keep the tension on the tow rope there could be a possibility of
tearing the eye off,
mark chandler
posted on 3/1/09 at 07:32 PM |
Mines welded to the plate that I landed the rear hoop stay on
NSR pic
Had not welded the hoop at this stage but you can see how I attached. Its was a front tow hoop from a classic range rover BTW
[Edited on 3/1/09 by mark chandler]
