New Topic New Reply
Author: Subject: side panel - interior trim interface
FASTdan
posted on 15/1/09 at 03:18 PM Reply With Quote
the PO of our indy has re-made the side panels in aluminium - well i think they are re-made, are they alu as standard? Well, he either re-worked the originals or made new.
On the top of the 'door' area, the panel is folded over across the top of the box section but not right the way across. on the inside of the car is an MDF trim card covered in vinyl. his intention was to make an alu channel as below to sit over the whole lot, clamping it all together and 'finishing' it off. however i am concerned that by doign this, the edge on the outside of the car (on the vertical face) will be an SVA fail as it may be considered sharp (using say 1mm alu sheet).
Am i right in thinking that?
Its the same situation with the curved box running over the front of the rear arch. he intended on doing the same, and forming the alu around a curved wooden former (that he gave me) - heating it using soap to indicate temperature. im not quite sure how this would work as i dont see where the excess material would go in the two channel flanges? i'd expect it to just ripple.
what else can you do in this area?
Mr Whippy
posted on 15/1/09 at 03:41 PM Reply With Quote
fold up some vinyl and wrap it over the edge for the SVA
JeffHs
posted on 15/1/09 at 03:56 PM Reply With Quote
In my opinion/experience it won't be a problem
I had a similar worry with infill pieces above my small rear arches. They were 1mm ali plates riveted on to the face of the body skin. SVA tester said was no problem at all. In fact he joked that you could use razor blades and still pass because they are thinner than the 1.5mm requirement for a 'blunted edge'
adithorp
posted on 15/1/09 at 08:49 PM Reply With Quote
As its only 1mm then it doesn't have to be radiused; Just "blunted". So if he runs his hand along it and it bleeds, then its not "blunted".
Just run a file lightly along the edge to take off the corner and it'll be fine.
adrian
http://jpsc.org.uk/forum/
New Topic New Reply
