tr
posted on 9/2/04 at 08:44 PM |
Steering Column
Can anyone tell me what I should use to fill this space? It's the hole in the bulkhead on an MK, that the steering column goes through.
Tom
theconrodkid
posted on 9/2/04 at 08:51 PM |
should be a plastic/rubber bush
who cares who wins
pass the pork pies
tr
posted on 9/2/04 at 09:08 PM |
He he, cheers.
Anything more specific?
The Halfords saturday boy got upset when I asked for a pair of nipples (bleed, of course). A plastic bush might tip him over the edge....
DEAN C.
posted on 9/2/04 at 09:24 PM |
Any discount motorists should keep in stock a sierra column bush kit, which new cost all of a few pounds£3 or £4 max if I remember.
This includes both the rubber grommet and the plastic bush.
DEAN............
Once I've finished a project why do I start another?
James
posted on 10/2/04 at 12:21 AM |
Lolocost will sell you the bush inner and outer (the bit you already have on the column) for £1.50 I think it is.
HTH,
James
MK9R
posted on 10/2/04 at 07:57 AM |
Here is what we have done.
It is a self centering bearing with the collet tightened onto the triangular column using a self made nylon bush.
Its alot stronger than the rubbish sierra one!
[Edited on 10/2/04 by MK9R]
Cheers Austen
RGB car number 9
www.austengreenway.co.uk
www.trackace.co.uk
Mave
posted on 10/2/04 at 05:12 PM |
I'm looking for donorparts, and need some help: do I need a specific type of Sierra column? I understand there are two types (new and old). Or
is it not important? And how about an adjustable steering column?
zetec
posted on 10/2/04 at 09:12 PM |
I used an adjustable one and have seen non adjustable so suspect you can use either.
tr
posted on 11/2/04 at 07:38 PM |
Ta very much for the replies...
I don't think £1.50 will break the bank.
Tom
