Stuart_B
posted on 27/2/09 at 06:50 PM |
pinto engine help
hi all, well, i am having a few more theething promblems with my mk. well on num4 cylinder the car was running great and between then and the next
time the num4 plug was complet shut up, not sure how it shut? any ideas how it did it?
then after that i opened the plug up, i put a new set of ht leads and i have been out a few times since and be great, but aftetr a while driving to
day, it started to run not right so i went home and exmined it, it seems to me that by taking num4 plug cap of made no differance on the engine
compraed to the rest. i have not checked it it does spark, but i did check that all the ends are good, but know setting where it might be my manifold
leaking on num 4?
any throughts?
by the way the engine is a 1.6 emax engine ruuning on cbr600 bike carbs.
thanks
stuart
aerosam
posted on 27/2/09 at 07:04 PM |
could you expand a bit on "running not right"? Is it misfiring, running on 3 cylinders, any nasty noises? etc.
All the best,
Sam
Had enough of this dictatorship known as LCB. Gone elsewhere, not coming back. Kiss my ass ChrisW.
Stuart_B
posted on 27/2/09 at 07:13 PM |
so soory, i all ways leave out the bit which is need.lol
well it started poping and i gussed it may not be running on all 4 such as it is running on 3, like i found out when i got home.
hope that helps with more info.
stuart
omega0684
posted on 27/2/09 at 07:24 PM |
have you put a new set of plug in?
Stuart_B
posted on 27/2/09 at 07:28 PM |
thay have done about 150 miles, but i think i will by a set saturday morning.
stuart
omega 24 v6
posted on 27/2/09 at 07:45 PM |
logic would say to check all the plugs again and see if 4 was shut up again. If it is then you may have problems. We used to have a high compression
pinto 2 litre with a skimmed head and the block deck machined as well. If you put the plugs in with the finger of the electrode in the wrong place
it'd shut the plug.
So you could have the wrong plugs for the engine or a highly altered high compression head/block plug clearance issue OR
if it's no4 again then perhaps a fecked big end or little end allowing the piston to come up farther than normal
Stuart_B
posted on 27/2/09 at 07:53 PM |
the plug, was open as it should be this time. so that puzzled me a bit, but then i throught maybe to much air geeting in the cylinder? or rotor arm or
cap?
could it to do with it being warm then cooling down and then using again?
about plug clearnce, i was talking to a person how skims his head down to the plug hole, i think about a 3mm skim he does. and he said you have to
make sure the electrode is in the right place.
could it be a vaule like that? or something different.
stuart
omega 24 v6
posted on 27/2/09 at 08:01 PM |
check for spark, check for fuel, and check for compression and see what results you get first.
delboy
posted on 27/2/09 at 11:05 PM |
When you change the plugs, make sure that you mark each one with the position of the electrode. When you put them in ensure that the mark sits at
between 10 o'clock and 2 o'clock. That way if you have a lot taken off of the head the piston will not hit and close the electrode. If you
haven't skimmed the head and decked the block its likely that you have a problem with number 4 conrod and big end allowing more movement on
number 4.
The Baron
posted on 28/2/09 at 09:27 AM |
I used to get terrible probelms wih my pinto if i used champion or NGK plugs. I went back to ford motorcraft plugs (2.0 spec) and i have never had a
problem since. Mine was also the emax engine.
B
Stuart_B
posted on 28/2/09 at 09:45 AM |
hi, well i had a look today, and my carbs has come off the manifold, so it is sucking to much air in. so looks like a new manifold needed.
thanks for all your help from every one, i will let you what happens.
stuart
