New Topic New Reply
Author: Subject: toe setting post SVA
jabbahutt
posted on 16/3/09 at 03:59 PM Reply With Quote
Afternoon all
With the weather improving and looking forward to finally putting some miles on the clock. The toe is still set to SVA with it out by about 1.5 degrees to aid self centring.
What should the proper settings be for normal driving afdter SVA?
Nigel
eddbaz
posted on 16/3/09 at 04:10 PM Reply With Quote
I've set mine neutral
whitestu
posted on 16/3/09 at 04:29 PM Reply With Quote
Mine is about 1 degree toe in.
stu
posted on 16/3/09 at 06:36 PM Reply With Quote
Little bit of toe-in that will go to neutral when you plant your right foot....
mad-butcher
posted on 17/3/09 at 12:24 PM Reply With Quote
Hi Nigel
Toe in. had mine out a few times round the block, M53-A55-top chester road- home, horrible trundling down the motorway at 69.9mph having every richard head wanting to race you and you know you've got another 5500 revs to go,after 40 odd years with a clean licence and a job that requires a clean licence. it's killing me
Just thought if your steering wheel is aligned properly take it about 1/4 turn each side so as you keep your steering wheel aligned,
tony
[Edited on 17/3/09 by mad-butcher]
New Topic New Reply
