chrsgrain
posted on 28/3/09 at 05:02 PM |
HVLP Paint problems - advice needed!
Hi Guys (and Claire and Fozzie!),
Tried my new HVLP gun today, but struggled a bit - paint looks like its drying on the way to the piece, lots of stringy bits on the edge of the spray
pattern and orange peel as well.
Tried fiddling with the settings, but not much improvement! I'm using quite thick and very quick drying self etching black satin paint -
I've diluted it 5% with top quality high gloss cellulose thinners (can dilute up to 10% max according to the data sheet, but didn't want
to overdo it - difficult to undilute it )
I've got a big compressor, with a moisture trap.... currently air is set at 60psi at the compressor.
Any advice gratefully received!
Chris
theconrodkid
posted on 28/3/09 at 05:26 PM |
pressure sounds a bit high for normal gun,i used about 35/40,no idea what pressure the lp guns work at....worth a try tho
who cares who wins
pass the pork pies
blakep82
posted on 28/3/09 at 05:35 PM |
whats 60 psi? about 6 bar? i think thats what i used, and it seemed to work ok when i did it...
doesn't the sray gun have any instructions about air pressure etc?
________________________
smart51
posted on 28/3/09 at 05:38 PM |
60 PSI is a little over 4 bar. Maybe it's a bit high for a low pressure gun.
tootall
posted on 28/3/09 at 05:43 PM |
the problem will be the thikness of paint
genraly u should run about 2 bar 30 psi u need to put it on wet celly is funny stuf there is a nac to applying it
to high pressur would cause it to attomise to fine and dry in air befor it hits pannel
so try lower pressur and good wet coats its suprising how much u can put on with out it running it all a matter of how dearing u are to hammer it
on. if u paint 2 pack all day it goes againt the grain to pile it on but it does work
some people dream of sucsess, others just get on and do it !!
posted on 28/3/09 at 06:17 PM |
Paint is much too thick pressure is much much too high
austin man
posted on 28/3/09 at 07:37 PM |
more thinners will do you definitely too thick especially if orange peeling and has stringy bits
Hugh Paterson
posted on 29/3/09 at 04:26 PM |
Paint is too thick, the pressure is way to high for hvlp. I use both HVLP and bog standard guns, im hovering around 15 - 20 psi on the pressure with
the HVLP guns, what has your chosen weapon got on it. U should have adjustment for pressure, volume of paint and spray pattern at least on a decent
HVLP. I start by setting the pressure at the compressor, fine adjust on the gun, its usually at the bottom of the handle, set the spray pattern at the
back usually wide fan too start with, then fiddle with the volume. If you are new to this try a variety of samples on a flat panel of similar material
to the substrate you are spraying. Aim for a wide/fine spray pattern to reduce the likelihood of orange peel + More thinners to start with, the tech
sheet for the paint will give u a guided to percentage of thinners, paint, and hardener required
Shug
