philhoward
posted on 15/4/09 at 04:15 PM |
Pinto Cam
I am going to fit a ported and polished stage 3 Burton head to my 2 litre pinto and am wondering which is the best cam to fit for fast road use. I
would rather go for something that does not need any modification to the pistons.
I am running ZX9R bike carbs and megajolt
Any suggestions welcome.
jacko
posted on 15/4/09 at 05:20 PM |
Hi i have a piper 285 cam fitted with the same carbs, but Bogg Brothers say if you have a big valve head use a A8 piper i don't know if you
would need to mod the piston tops with a A8 cam,
My 285 fitted with no modifications
Give Boggs a phone call there very helpful
Jacko
snapper
posted on 15/4/09 at 05:21 PM |
285 duration is a safe bet and should work well from 2500 to 7000.
You should be able to run a 300 duration cam but if you skim the head you will need to check clearance.
Talk to Burtons.
Go for about 10.2 to 1 compression ratio and a red line of 7200 with un modded injection rods
I eat to survive
I drink to forget
flak monkey
posted on 15/4/09 at 05:33 PM |
I would look at the FR33 kent or the 285 piper.
If its for road use it will be a lot more driveable than with a race type cam.
Sera
http://www.motosera.com
omega0684
posted on 15/4/09 at 05:46 PM |
where are you and what you doing with your old head?
delboy
posted on 15/4/09 at 05:48 PM |
You could go a little more radical than the fast road cams mentioned above and use a race cam like a Kent HT1, to get the best out of it you would
need to skim the head and it will be a little lumpy on idle, it really depends on your bottom end too, if it's pretty bog standard you might
find that the extra revs and strain on the rod bolts would make it unreliable.
philhoward
posted on 15/4/09 at 06:10 PM |
I am in New Milton, Hampshire. I am not sure what to do with my existing head yet. Why do you ask?
Phil
jacko
posted on 15/4/09 at 06:21 PM |
What BHP are you looking to get out of your engine ?
gregs
posted on 15/4/09 at 06:31 PM |
I think you'll find as many answers as there are cams! - I have an FR34 fitted, but not running properly yet.
philhoward
posted on 15/4/09 at 06:44 PM |
Not sure what BHP I will get, but hopefully as much as possible
jacko
posted on 15/4/09 at 06:50 PM |
On zcars R Road i got 150bhp at the flywheel
2.0 pinto
rebore +60th
head planed by 1mm polished ported
zx9r carbs
modifide dizzy
Piper 285 cam
jacko
[Edited on 15/4/09 by jacko]
