FASTdan
| posted on 20/4/09 at 03:36 PM |
Indy cycle wing bracket failed.....
After approximately 10 hours use the passenger side cycle wing mount on our indy failed. The top support snapped - presumably a fatigue failure as the
wings do wobble around constantly.
Anyone else had this?
I welded ours back up and then braced across the corner with a piece of st st flat and that has worked a treat in preventing the wobbling on both
sides.
A1
| posted on 20/4/09 at 04:36 PM |
you mean the bit thats attached to the upright? mine are both okay, after loads of miles...
mangogrooveworkshop
| posted on 20/4/09 at 05:43 PM |
sides.
welcome to the club........when the other one falls off give fozzie a U2U and she will give you the secret code to the shop link.
ps A1`s tellin fibs his didnt have time to fall off......
Do a search loads have fallen off
[Edited on 20-4-09 by mangogrooveworkshop]
James
| posted on 20/4/09 at 05:55 PM |
"Anyone else had this?"????
If yours haven't fallen off you haven't been driving the damn thing.
It's standard procedure when you hit about 1500miles
Pity the other manufacturers haven't copied the excellent MNR design it wouldn't happen then.
James
- Muhammad Ali
| posted on 20/4/09 at 06:07 PM |
Mine haven't fallen off but then they're the agricultural STM 5mm bar supports so they're never going to bend or break!!! They
usually made them from thinner material but also had a problem with fracturing so I chose the chunky ones....
FASTdan
| posted on 21/4/09 at 11:41 AM |
James
LOL fair enough I'm far from alone then
mads
| posted on 21/4/09 at 12:27 PM |
James
whats the difference in the design James? and does the MNR ones fit other sevens?
We gain knowledge faster than we do wisdom!
Life is not a journey to the grave with the intention of arriving safely in a pretty and well-preserved body, but rather to skid in
sideways, thoroughly used, totally worn out and loudly proclaiming... "f*ck, what a trip!"
| posted on 21/4/09 at 06:04 PM |
Our original MK wing stays did 3,000 mile in the first Indy, survived a head on collision with a lamp-post, did another 7,000 miles on the second Indy
and have since been sold on to another forum member to enjoy for years to come.
The wing stays were still in perfect shape even after this crash test
Phil
eccsmk
| posted on 21/4/09 at 07:45 PM |
mine are still in tact
altho i used 5mm flat steel on top and it was forced into the tubes about 3"
bigpig
| posted on 24/4/09 at 08:48 PM |
Mine are doing fine
Although its not on the road yet, my my head is decidedly feeling 2nd hand after I caught it on the wing bracket. Bled like a stuck pig I did
