EasyJimbo
| posted on 18/5/09 at 01:51 PM |
rivet size for floor
Guys
I see from the MK build manual that you are suposed to use 5mm rivets for the floor, but the rivet tools such as the lazy riviter etc only come with a
4.8mm attachment as the biggest it can take. Am I getting something wrong here or did you use smaller rivets than MK suggest?
thanks
J
be gentle I am new to all this :-)
blog: http://mkjimbo-mkindybuild.blogspot.com/
omega0684
| posted on 18/5/09 at 01:53 PM |
3/8 rivets every 2" is fine, remember to use bonding agent as well
EasyJimbo
| posted on 18/5/09 at 02:06 PM |
great thanks, so 4.8mm is fine then.
J
procomp
| posted on 18/5/09 at 02:13 PM |
Hi
And make sure they are sealed rivets. Otherwise all the water / moisture will ingress to the inside of the chassis.
Cheers Matt
EasyJimbo
| posted on 18/5/09 at 02:24 PM |
Thanks. If i use a 4.8mm tivet what size drill do I need to use to drill the hole, obviously if I was using a 5mm rivet I would probably use a 5mm
drill bit, but not sure if I am using a 4.8mm?
thanks
J
| posted on 18/5/09 at 02:43 PM |
5mm drill is fine... they swell up to fill the hole size anyway.
S
speedyxjs
| posted on 18/5/09 at 02:44 PM |
5mm drill bit will be fine.
I used these.
EasyJimbo
| posted on 18/5/09 at 02:51 PM |
thanks for your help guys
J
Stuart_B
| posted on 18/5/09 at 05:06 PM |
as, said, thoses size rizets are fine with a 5mm hole and some glue, i used silcone, some use tiger seal or sikaflex.
stuart
tomblyth
| posted on 18/5/09 at 09:02 PM |
best money you'll ever spend will be one of these!
link
