New Topic New Reply
Author: Subject: Throttle pedal-Clutch pedal top hats???
Dan
posted on 19/5/09 at 03:13 PM Reply With Quote
On a mk chassis what is used as a top hat to secure your clutch and throttle cables in the two metal tubes welded to the chassis. thanks
Stuart_B
posted on 19/5/09 at 07:18 PM Reply With Quote
hi, on the throttle cable i used a bit of m16 studdin and m16 not, drilled down the center, and taped on end, which i seruced an adjuster in, adn passed my push bike brake cable through,but is because i have bike carbs,
and on the clucth i used a caori clucth cable which fit in ther prefect, nad put a sprin on teh other side to keep tension.
hope taht make sensce, if not i will try and dig out a photo, of the clutch.
stuart
edit, here is a pic of the throttle cable: 2
2
[Edited on 19/5/09 by Stuart_B]
Dan
posted on 20/5/09 at 08:31 AM Reply With Quote
Thanks for your reply Stuart, i was thinking of having some alloy turned down to fit in the tubes was after some feed back what others have done.
New Topic New Reply
