jpindy3
| posted on 21/5/09 at 08:28 PM |
cycle wings
hi all,
has anyone had any issues with the cycle wing braket snaping?
it ant happend to me yet,but i did read some where it happens.
is it just mks that have this problem?
jamie
| posted on 21/5/09 at 08:31 PM |
It can happen to almost any make - mine's broken 3 or 4 times now! (book Locost).
It's all to do with a weight (the wing) flapping around on the stays and causing fractures.
[Edited on 21/5/09 by David Jenkins]
skippad
| posted on 21/5/09 at 08:36 PM |
both of mine on my Mk have snapped recently.
They both snapped on the front flat bar just above the weld on tubular section.
Its a common trait, welded back on and beef up with extra weld.
PAUL FISHER
| posted on 21/5/09 at 10:08 PM |
The MK cycle wing brackets are no more prone to breaking than any other cycle wing bracket,as the metal strip used is 5mm thick,Ive never had one
break on either of my Indys,in many thousands of miles,In my opinion the main problem is when fitting them,ensure you
bend them once correctly. If you keep bending unbending them to get them to fit,your end result will be metal fatigue
| posted on 22/5/09 at 12:26 AM |
What Paul said.....
S
