Coopz
| posted on 24/5/09 at 03:10 PM |
Have I done something wrong?
Reading through an old post, it says that the rear sierra hub nut should always tighten to the front of the car. Well I have put my driveshafts on and
hub carriers etc and the passenger side tightens to the front but to tighten the drivers it tightens to the rear? I have tightened them both to 200nm
is this ok?
Also the driveshaft and the hub nut sticks out the centre of the wheel and I cant get the centre cap on any ideas how to sort this?
[Edited on 24/5/09 by Coopz]
sprouts-car
| posted on 24/5/09 at 03:11 PM |
seems so
blakep82
| posted on 24/5/09 at 03:12 PM |
pressed post without writing anything by the looks of it...
how do so many people manage to do it?!
________________________
Coopz
| posted on 24/5/09 at 03:14 PM |
Thats better... A question now posted too
repper
| posted on 24/5/09 at 03:26 PM |
right-hand thread on all modles manufactured before late december 1982 but as from this date left-hand threaded assemblies wear progressively fitted
to the right-hand splindle carrier.
the modified right-hand hub is identified by the letter 'R' stamped on its outer face.
[Edited on 24/5/09 by repper]
prawnabie
| posted on 24/5/09 at 03:28 PM |
Never done one, but I have always read that the huts were handed thread and there was a blue and a yellow band on them to tell you which was which?
Are the driveshafts recon units or straight off the donor. I have seen in the past recon unit suppliers use what was available at the time instead of
what should have been used.
Shaun
MautoK
| posted on 24/5/09 at 03:41 PM |
quote: Originally posted by prawnabie
... and there was a blue and a yellow band on them to tell you which was which? ...
Eyeballing the thread saves having to remember which band means what.
John.
Coopz
| posted on 24/5/09 at 04:47 PM |
Shaun
Aha They are reconditioned driveshafts meant to be exact replicas of the old donor ones i sent off.
Is this going to be a problem then? also is 200nm tight enough?
