heyzee
posted on 3/3/04 at 09:01 PM |
in line brake switch
have all of you chaps that are useing floor mounted pedals useing the in line brake switch??if so where do you position it and how mutch are they and
where can i get one
Kitlooney1000
posted on 3/3/04 at 09:16 PM |
i think merlin, and demon tw*ts do them, around £15 for the body about £7 for the switch. Rally designs do them for about £15 for the pair, thats
where mine came from. I put mine on the front brakes and used it to split into 2, one for each side
bob
posted on 4/3/04 at 12:06 AM |
Dave
have a look in my photo archive,theres a pic or two of switch.
Mines at rear,which makes sense as thats where the stop lights are
JAG
posted on 4/3/04 at 08:53 AM |
I got one of these switches for <£5 at the Stoneleigh show last year.
Can't remember who from, one of those stalls with lots of little wooden boxes and everything from brake switches to chrome badges etc...
Justin
posted on 4/3/04 at 08:55 AM |
heyzee,
ditto what Bob says, I have some photos of the rear brake pipe routing in my archive, showing the in line switch position.
HTH
Nick
locoboy
posted on 4/3/04 at 09:01 AM |
Mac1 motorsport £6 + couple of quid P+P.
Locoboy
posted on 5/3/04 at 10:29 PM |
Location
ours is at the front cos that's where the fusebox and reservoir are less wires.
Soz Bob...
[Edited on 5-3-04 by Hellfire]
bob
posted on 5/3/04 at 10:45 PM |
No prob,i saw a few with the pressure swich at the back so copied.
Must admit i've seen a few at the front since,but i didnt have a prob with wires as premier wiring looms give you plenty.
posted on 6/3/04 at 08:37 PM |
But...
think of the extra weight...
Must a few extra grams there... talking of white lines....
As long as it works!!!
Deckman001
posted on 7/3/04 at 04:56 PM |
Hell fire, just saw your pic, what happens if you get any air in the system, the first 'high' point into the system is your brake switch
!! sure it will still work ??? might be worth turning it over to prevent any such problems ??
Jason
mad-butcher
posted on 7/3/04 at 07:47 PM |
switch off vw golf T peice off donor sierra.
any good motor factors
posted on 21/3/04 at 08:33 AM |
Just point out the switch must go in the FRONT hydraulic circuit as stated old construction and use regs. If you have in the rear circuit even if
you get through the SVA an MOT tester can fail you, or Traffic cops can book you.
bob
posted on 21/3/04 at 09:37 AM |
Can someone confirm where the pressure switch is located on VW golfs ?
I believe they are at the rear of the car in the rear circuit.
theconrodkid
posted on 21/3/04 at 09:44 AM |
on the bulkhead in the front pipework just above the gearbox
who cares who wins
pass the pork pies
bob
posted on 21/3/04 at 10:02 AM |
cheers
alister667
posted on 23/3/04 at 09:25 PM |
Mine just went through an MOT yesterday with the switch on the rear circuit - exactly the same as hellfire's setup. As well as this as far as I
know all westfields have their switches in the same place (well the BECs anyhow).
Just wondering I don't see it mentioned whereabouts is this in the SVA manual? Also why does it matter - surely the action of the master
cylinder works on all 3 (in the case of the sierra) lines?
Ali
http://members.lycos.co.uk/alister667/
bob
posted on 23/3/04 at 11:36 PM |
Yep mines at the back and staying there now,as you say the westfields are located there i just copied them.
posted on 26/3/04 at 07:19 PM |
Ali
Its the law and has been since brake lights were first legally acknowledged -- not all testers are on the ball enough to pick it up or even know about
it. Because it is pretty obscure it isn't covered in the MOT testers training course and likely not in the SVA course either.
The history behind it is that when brake lights were first fitted some cars still had a mechanical rod or cable brakes, often the pedal was connected
only to the front brakes or slightly better to the front and a transmision brake. Normal stopping procedure was to use the foot brake assissisted by
gentle aplication of the handbrake.
[Edited on 26/3/04 by britishtrident]
posted on 26/3/04 at 07:31 PM |
On the side of the master cylinder -- the Golf m/cylinder usually has 6 tapped bosses, one for each wheel plus two brake switches Golfs I have
worked on had a diagonal hydraulic split with a two switches one on each circuit..
Usually the terminnals on brake switches on older Golfs fall off if you try and disconnect them -- Geman quality.
