40inches
| posted on 28/5/09 at 06:21 PM |
Seat belt anchorage points
Can someone please measure the distance from the bottom anchorage points to the back panel?
I have 90mm, this seems very close, as the points are well behind the seats on mine
speedyxjs
| posted on 28/5/09 at 06:28 PM |
Mine are also well behind the seats but that was the only place i could weld them in more than one place
ashg
| posted on 28/5/09 at 07:04 PM |
its 140mm on the haynes roadster if that helps
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
Stuart_B
| posted on 28/5/09 at 07:43 PM |
hi, do not know the messurements, but there are 2 photos, if that helps you
here
stuart
40inches
| posted on 29/5/09 at 01:00 PM |
here
stuart
From these photos it seems that MK moved the mounts, at some point in time, from 90mm to around 160mm. Another job on the list of things to do
Thanks for the help guys.
Image deleted by owner
speedyxjs
| posted on 30/5/09 at 07:34 PM |
Why the need to move it?
40inches
| posted on 1/6/09 at 12:09 PM |
The mounts are around 150mm behind the harness slots in the seats and put the belt right at the back vertical edge of the slot, probably why MK moved
them forward on later chassis, plus, the mount is exactly where the bracket for the starter motor will fit
