New Topic New Reply
Author: Subject: MK Spec R steering
Breaker
posted on 6/6/09 at 10:04 AM Reply With Quote
MK Spec R steering
In the early phases of building an Mk Spec R, I have a question regarding the steering rack. I've been using the "search" for a while but I'm still confused.
As I understand correct, the sierra rack is too long and should be cut. Do they cut the rack or also the housing and how much?
I also read about an escort rack that shouldn't be cut.
Which solution did you use/recommend ?
fesycresy
posted on 6/6/09 at 10:09 AM Reply With Quote
I thought that shortening the rack was part of the deal when you bought an Indy ?
Speak to MK.
ReMan
posted on 6/6/09 at 10:11 AM Reply With Quote
Still on the front page, just http://www.locostbuilders.co.uk/viewthread.php?tid=114908
PAUL FISHER
posted on 7/6/09 at 03:59 AM Reply With Quote
Both the rack,and housing{body} are shortend on the donor"SIERRA" steering rack to fit the MK Indy R chassis,this reworked rack is supplied with the Indy R kit,although there may be a small surcharge if you have not supplied them with a donor rack,also if you require a quick rack there is also additional charge.
A1
posted on 3/7/09 at 09:49 AM Reply With Quote
my rack was untouched...?
sickbag
posted on 3/7/09 at 11:40 AM Reply With Quote
Here's a picture of mine. They cut out a section and welded in another, and fitted a quick rack at the same time for me. I supplied the original rack.
The measurement is from where the lip for the gaitor just start.
MK rack
MK rack
Finally back on the job!
New Topic New Reply
