New Topic New Reply
Author: Subject: Fuel pipe and Brake lines
EasyJimbo
posted on 6/6/09 at 12:25 PM Reply With Quote
Hi guys
Can anyone reomend what fuel line I need and where I can get this from? Also I have the delux kit from MK which has brake pipes set in but I guess i will need further brake pipes will I? if so what spec and where is best to get these?
thanks
J
[Edited on 7/6/09 by EasyJimbo]
be gentle I am new to all this :-)
blog: http://mkjimbo-mkindybuild.blogspot.com/
EasyJimbo
posted on 7/6/09 at 03:57 PM Reply With Quote
Anyone?
Staple balls
posted on 7/6/09 at 05:49 PM Reply With Quote
Depends what you got in your brake line kit from MK.
Usual fuel line is 8mm copper microbore heating tube + correct marked rubber pipe to suit your engine/fuel of choice.
posted on 7/6/09 at 05:59 PM Reply With Quote
You should have enough brake pipe to run your brake lines but it ultimately depends on how/where you route it. If you run out, have a word with MK.
With regards to your fuel line, you're better off measuring the existing fuel fittings on the engine/fuel pump and then getting some copper microbore like Mr Balls says Most good DIY places will sell it. You then need flexible fuel hose to connect each end.
Phil
New Topic New Reply
