greggors84
| posted on 10/3/04 at 09:01 PM |
Pedal Box Tubes
What have people used to close up the end of the tubes coming from the pedal box to the engine bay.
I know hellfire has made some tophats but i dont have access to a lathe so cant do this.
I need someway of holding the cable so the inner can be pulled.
Any pics would be very useful.
Chris
The Magnificent 7!
ady8077
| posted on 10/3/04 at 09:59 PM |
Hi
If you mean for the throttle cable just use pushbike brake cables and adjuster
Adrian
| posted on 10/3/04 at 10:08 PM |
Tophat's
I'm sure someone can help greggors84 out... this is what he means.
Unfortunately we have use of a lathe very rarely... otherwise we'd have made him some . You do need something to prevent the outer from
pulling through the tube. This works admirably by placing the adjuster before this and then the inner threads through to a banjo and secures to the
pedal.
[Edited on 10-3-04 by Hellfire]
ady8077
| posted on 10/3/04 at 11:30 PM |
Hi
Didn't realise you meant clutch cable, mine had a plastic coller at the pedal end which stops it pulling through and the adjuster at the gearbox
end, standard MK2 escort
What diamiter is the tube? how about drilling through a close fitting bolt?
Adrian
greggors84
| posted on 11/3/04 at 03:34 AM |
Thanks hellfire, you did a better job explaining in with the picture.
I could maybe get some plugs that fit the hole then make a hole in the middle for the cable.
What did you mean about the bike brake bits?
Chris
The Magnificent 7!
MK9R
| posted on 11/3/04 at 08:09 AM |
We did the same as hellfire in the end but used nylon. Although to start with we used the ends of an Autobox gear selector cable.
Cheers Austen
RGB car number 9
www.austengreenway.co.uk
www.trackace.co.uk
vintagebuilder
| posted on 11/3/04 at 04:14 PM |
Pedal Box Tubes
Afternoon All,
The Indy that Charlie at MK was building had alloy "top hats" in the bulhead tubes.
Perhaps Mk sell them?
Hope this helps.
