New Topic New Reply
Author: Subject: Drum brake assembly question
L5W
posted on 10/7/09 at 07:20 PM Reply With Quote
I'm putting the drum brake plates on the rear uprights and have noticed that there are a couple of raised sections on the back of the plates which press against the hub carrier itself when assembled. Is this ok?
I did a quick forum search and couldn't find anything so probably means I'm being over cautious or I've done something wrong!
brake plate 2
brake plate 2
brake plate 1
brake plate 1
Thanks,
Lee
lotusmadandy
posted on 10/7/09 at 08:04 PM Reply With Quote
When i built my indy it had drums and the
backplates looked just like that.
As long as the plate if flat against the upright and not deformed, it is ok.
L5W
posted on 11/7/09 at 07:10 AM Reply With Quote
Thats good to hear, thanks for the reply Andy
Lee
dave shires
posted on 28/7/09 at 10:47 AM Reply With Quote
rear brake plate
I am also building an Indy R and have the same problem to combat the issue I have decided to fit discs to rear
New Topic New Reply
