New Topic New Reply
Author: Subject: camber
eccsmk
posted on 19/7/09 at 10:26 PM Reply With Quote
camber
where can i get some sleeved tubes(?)
they are fitted into the wishbone where the drag link fits to save undoing the draglink when you want to adjust the camber
sorry ive not explained that very well
Steve Hignett
posted on 19/7/09 at 10:29 PM Reply With Quote
You'd need to get wishbones to suit aswell...
eccsmk
posted on 19/7/09 at 10:45 PM Reply With Quote
ah i thought i could have the threaded tubes machined out to suit
blakep82
posted on 19/7/09 at 10:58 PM Reply With Quote
given what you have already on the car, would undoing the 2 wishbone bolts spinning the wishbone round, and putting them back in be easier?
________________________
Flamez
posted on 20/7/09 at 07:27 AM Reply With Quote
This is what you are looking for. Top wishbones need tubing to take them
http://www.rallydesign.co.uk/advanced_search_result.php?keywords=camber&osCsid=44lajsmgunkm62u1c2jqdhbuh6
my build mac1motorsports
tomgregory2000
posted on 20/7/09 at 07:28 AM Reply With Quote
i got my tubes machined out to accept the camber adjusters from rally designs, and then some plates welded on top and bottom due to the reduced wall thickness.
The reason for fitting these blake it so that the camber can be set up propperly rather than adjusted 1mm at a time
eccsmk
posted on 20/7/09 at 08:25 AM Reply With Quote
you lot are brilliant and all deserve a nice cold pint
am i best to have the tube reinforced
replace it
or have new wishbones made (which i can do if i can get my local firm to bend the tubing)
tomgregory2000
posted on 20/7/09 at 08:39 AM Reply With Quote
i can get some pictures up here if you want,
i went down the reinforced route as there was about 2mm of wall left and oh i got it all done for free
jabbahutt
posted on 20/7/09 at 08:49 AM Reply With Quote
You need to contact Wozsher on here. He makes replacement top wishbones for the Indy incorporating that type of camber adjustment.
Top bloke to deal with and his product is excellent, also inproves self centring over the original MK items.
mad-butcher
posted on 20/7/09 at 03:53 PM Reply With Quote
These are what you need, as said contact wozsher,
eccsmk
posted on 20/7/09 at 08:17 PM Reply With Quote
i would love to contact him and order a set
but times are hard
very hard infact
so im going to try and keep it all as locost as possible
but thankyou for the recomendation and the piccy
Jumpy Guy
posted on 24/7/09 at 04:12 PM Reply With Quote
Anyone got some pics of the wozsher wishbones fitted?
Got mine delivered, and woudl be helpful to see some fitted before i do it myself...
Cant get Warren on the phone, so Im after some guidance........
New Topic New Reply
