david
| posted on 28/7/09 at 07:22 PM |
MK front suspension springs
I got a complete MK kit and the front springs are very hard even when slackened right of. I have been told that the springs should be 225. Are the
springs marked or how do you know the spring pressure. The shocks are proton. David
mackei23b
| posted on 28/7/09 at 07:25 PM |
Spring rate should be marked on the top of the spring seat.
Ian
Guinness
| posted on 28/7/09 at 07:30 PM |
My MK springs have very faint very small white writing on the coil itself.
HTH
Mike
ReMan
| posted on 28/7/09 at 07:36 PM |
Weight is "painted" onto the flats at one end
What engine do you have?
Kriss
| posted on 28/7/09 at 07:43 PM |
I have a pair for 225's waiting to be fitted to my R1 Indy, front is just compliant and way to stiff
mangogrooveworkshop
| posted on 28/7/09 at 08:11 PM |
they will be 325`s
| posted on 28/7/09 at 08:25 PM |
Front springs are 350's provided by MK as standard unless you specify different. My advice would be to fit them and try them for yourself before
deciding to change them.
Phil
MikeCapon
| posted on 28/7/09 at 08:35 PM |
Here's how to find what springs you've got even if you can't read the numbers that were on the spring.
david
| posted on 28/7/09 at 10:13 PM |
suspension springs.
where is the best place to get 225-250 springs
procomp
| posted on 29/7/09 at 07:13 AM |
Hi
One other thing to check is that the suspension brackets and bushing is not binding. Try slackening of the front suspension bolt and then see if that
improves the compliance ( common problem) . Even with 350Lb fitted you should be able to bounce the car with the dampers set to a low number of
clicks.
Cheers Matt
Kriss
| posted on 29/7/09 at 12:20 PM |
i got mine from merlin - faulkners - were cheaper than direct from faulkners themselves
Hi Matt @ Procomp btw!
