Blackcab
| posted on 7/8/09 at 09:47 PM |
Propshaft Bracket
Is it necessary to use a bracket to support the propshaft - I see no mention of it any where apart from in the RAPTOR build manual
http://www.kitsnklassics.com/buildmanuals/Raptor_build_manual.htm
- has anyone else put a support bracket in and can I have a pic ?
Jon Ison
| posted on 7/8/09 at 09:51 PM |
If your using a two piece prop with center bearing then a support bracket is a must.
Blackcab
| posted on 7/8/09 at 10:08 PM |
Mine is a single piece - are these an off the shelf part or is it fabrication time ?
Staple balls
| posted on 7/8/09 at 11:15 PM |
If it's single piece, you don't need one (it'd be a bad idea)
And the one in that link appears to be a pillow block bearing, so off the shelf
blakep82
| posted on 7/8/09 at 11:44 PM |
if you got a single piece prop (i think the best way, others may think differently) but no centre bearing needed
________________________
mad-butcher
| posted on 8/8/09 at 07:55 AM |
Thought I was reading the MK build manual not a raptor one, looks like a direct rip off
tony
Blackcab
| posted on 8/8/09 at 10:13 AM |
I think its the Same car - chassis and panels look the same
