Angus180
| posted on 13/8/09 at 09:24 AM |
Loud metal to metal screaching
hello, my mk indy with ford drums is not good.
this problem developed the other evening when ever i go around a left hand corner with a bit of speed the rear right drum/drive shaft area schreaches.
it is only ever when i load the rear right on left hand corners, at low speed it is ok. what can it be???
mookaloid
| posted on 13/8/09 at 09:43 AM |
Something is catching or you have a stone or something stuck in there somewhere - you need to to take the wheel and possibly the drum off to have a
look for evidence of rubbing or a foreign body.
Mr Whippy
| posted on 13/8/09 at 09:47 AM |
I'd check the wheel bearing tightness too, especially if its only going round corners.
Also possibly one of the brake shoe retaining springs has snapped and the shoes side is rubbing on the drum.
Angus180
| posted on 13/8/09 at 10:02 AM |
i'll have a look, im not sure what drums they are, it says ford on them? and how about parts? i'll have a look for a part number ect.
miikae
| posted on 13/8/09 at 10:16 AM |
Quite possible that brake shoe retaining spring has come adrift , only last week i stripped mine as the drum was getting excessivly hot so stripped
it and cleaned out the crud/dust etc and all's well now, i found the inspection bung was missing on that drum so a grommet was found that just
fitted.
Mike
If it can be done it i will be done .
iscmatt
| posted on 13/8/09 at 12:04 PM |
check for stones too especially if there are road works near you
Angus180
| posted on 13/8/09 at 04:57 PM |
all sorted, the bracket holding the altenerator on snapped and the blades were hitting the chassie when the engine moved on left hand corners, also
the engine mounts are soft so the engine moves abit.
