Coopz
posted on 8/9/09 at 10:27 AM |
Wilwood brakes
I've searched through many of the previous posts about wilwoods but haven't found the answer i'm after.
Ok so i'm running wilwood powerlite on the front with mintex pads... (The car is still in build stage) So generally i'm after the
powerlight handbrake caliper. But after talking to MK they were very down on these has anyone got any experience with them is the handbrake that
bad?
My second question is i'm stumped on what to order from rally design they do two kits one for disc and one for drum hubs (apparently the hub
needs to be lathed down) which i don't fancy doing! I know I have drum hubs but have the disc adapter plate from MK does this mean if i order
the disc setup they will fit and i get away without the lathe?
Anyone had any experience with this as i don't want to have an expensive mistake!
Flamez
posted on 8/9/09 at 10:41 AM |
I have rear powerlights with handbrake. They work just fine once bedded in. The only drawback is that the handbrake mechanism, lever, on the caliper
protrudes outside the caliper casing. This makes fitting 13" rear wheels difficult. The only make I have found that give clearance are 13"
team dynamics pro race 1.2. i think 14" and above would be ok.
See here for a picture.
my build mac1motorsports
Frosty
posted on 8/9/09 at 10:45 AM |
Rally Design told me that the hand brake is terrible and doesn't work very well at all.
turbodisplay
posted on 8/9/09 at 10:50 AM |
Nowdays so many cars have good handbrake calipers it is worthwhile using these. I have one from a vx220 (elise is same) on 25mm vented discs.
It works quite well, although i have heard of cars rolling, due to thermal contraction.
Personally i don`t think they put the handbrake on enough.
Darren
Coopz
posted on 8/9/09 at 10:52 AM |
Thats good to know, I have 15" 1.2 pro race so clearance shouldn't be a problem any idea which kit to order though were you running drum
or disk hubs? did you need to lathe down your hubs?
[Edited on 8/9/09 by Coopz]
adithorp
posted on 8/9/09 at 10:54 AM |
The hub flange has to be reduced in diameter to fit the disc (fiesta I think)thats supplied with the kit.
The powerlite handbrake caliper isn't the best engineering solution. It lacks leverage in some instalations (Fury) and I had to put an extra
lever mechanism in to get it to work. In theory it needs constant adjustment as the pads wear; Having said that mine works well and after 4000miles
has only just been adjusted for the first time and my extra linkage should make it need more adjustment.
13" Compomotive CXR's fit ok.
adrian
http://jpsc.org.uk/forum/
Gav
posted on 8/9/09 at 11:33 AM |
I've got them too.
The handbrake will hold the car on a hill, for instance it held the car on the incline of the car trailer i used for SVA so maybe a tad over 30/35
degree?.
This did require a really good pull on the handbrake though.
If i was to leave it on a hill i would keep it in gear just in case!
big-vee-twin
posted on 8/9/09 at 11:56 AM |
Your drum brake hubs need to be turned down to 134mm diameter to fit the disk brake kit sold by Rally design
linky
http://www.triangleltd.com
A1
posted on 8/9/09 at 01:02 PM |
Ive heard the wilwood handbrakes arent too great, Im thinking of getting hi spec rear calipers.
or...how about getting a spot caliper? Ive checked it out, hispec do them for 65quid each. dont think ill go for it due to the extra weight.
Coopz
posted on 8/9/09 at 04:50 PM |
linky
How exactly can this be done bit worried about doing it my self? any pictures?
