Angus180
posted on 8/9/09 at 05:44 PM |
2 rads and still no where
ive bouth oneradiatior from a scrap yard which is no good wont flow enough, bough one rad of ebay for again £20 and the pipe connection is slightly
off and the rad is to long, so now im gonna try to find a polo but where from? any one point me in the right direction b4 i go mad
Jon Ison
posted on 8/9/09 at 05:57 PM |
here you go
will121
posted on 8/9/09 at 06:01 PM |
i thought i was getting a bargin but went through 2 second hand radiators, in end got a new one local motor factor think under £50,
[Edited on 8/9/09 by will121]
Davg
posted on 8/9/09 at 07:35 PM |
Angus
there is also GSF carparts if there is a branch near you . A bit deared than Jon's post though!
cheers D
Angus180
posted on 8/9/09 at 08:27 PM |
cheers hopefully it will stop my over heating problems
Angus180
posted on 11/9/09 at 05:03 PM |
ahhhhh, 3rd radiator now costing 70 quid, the one i orded from the link from jon and it doesnt fit its a 1990 rad, do i need the 81 rad 1.3 polo 380
x 320 x 32, do i want the vw14, vw 10, vw3 all slightly differnt, also do i will have to ditch expansion and find a header tank!!!!!!!!!!!!!!!!1
Angus180
posted on 11/9/09 at 05:09 PM |
ive ordered this off the link
http://www.northernradiators.co.uk/product_catalogue/volkswagen_polo_90_radiator_vw15/index.html it doesnt fit take it i need this one
http://www.northernradiators.co.uk/product_catalogue/volkswagen_polo_90_radiator_vw15/index:search.html
and take it i need this one vw 14 rad
Jon Ison
posted on 11/9/09 at 06:31 PM |
This was the one in the link
[img]http://www.northernradiators.co.uk/product_catalogue/volkswagen_polo_90_radiator_vw15/index.html[/img]
Will it not lay back ?
Angus180
posted on 11/9/09 at 06:47 PM |
no its to wide and i tryed lay bk and it was almost horozontal. plus i need to remove my expansion tank and try and find a header tank do you konw
what one will fit and does it have to be higher than the radiator
Jon Ison
posted on 11/9/09 at 07:01 PM |
It should be 430mm wide ? Mine is wider than that and goes in almost upright ?
Angus180
posted on 12/9/09 at 01:28 PM |
the widest part is 525mm the actuall metal core is 430mm
Angus180
posted on 12/9/09 at 01:41 PM |
im gonna buy the smaller polo rad and try to fit a header tank and hopefully it will fix the problem.
