New Topic New Reply
Author: Subject: Rose Jointed Chassis
MikeFellows
posted on 20/9/09 at 09:01 PM Reply With Quote
As per previous post I recieved my kit yesterday
I went for a full rose jointed chassis so the kit came with 20 rose joints that needed to be attached to the ends of all the wish bones and the bar that connects the suspension rocker thing to the front wishbones (as per standard kit).
I put the bolt through the standard chassis holes putting the bolt through the rose joint, however this means that the rose joint can slide along the bolt meaning that my whole front wish bone has the ability to move forward and backward.
Should I have got some spacer type things that go over the bolt to hold the rose joint in a single posistion?
Mike
austin man
posted on 20/9/09 at 09:04 PM Reply With Quote
Did you get a plentifull supply of washers ? use these they will allow for further adjustments
MikeFellows
posted on 20/9/09 at 09:09 PM Reply With Quote
I would need at least 50mm of washers on the wider sections, which seems a lot.
I will speak to MK tomorrow as they didnt give me a build manual which doesnt really help
prawnabie
posted on 20/9/09 at 09:10 PM Reply With Quote
Oh dear not another one!
RichardK
posted on 20/9/09 at 09:35 PM Reply With Quote
When packing out rose joints I would use something like this too, LINKY
obviously the correct size and would combine these or similar with washers.
Just my view.
Rich
Gallery updated 11/01/2011
blakep82
posted on 20/9/09 at 11:36 PM Reply With Quote
misalignment spacers are the right way to do it as above^^
washers are acceptable i'm told (and hope ) as the misalignment spacers are v-expensive. especially when you need 36 of them...
MK should really have supplied something with the chassis i guess (especially if they've supplied all the rose joints)
best check with them really
________________________
Canada EH!
posted on 20/9/09 at 11:58 PM Reply With Quote
Two misalignment washers per rose joint, one on either side of the joint to allow for it to swivel, then washers or spacers of the proper size to set the alignment.
eddbaz
posted on 21/9/09 at 08:41 AM Reply With Quote
Build manual ? You have two chances, slim and none, and slim's left town
Mr Whippy
posted on 21/9/09 at 09:33 AM Reply With Quote
^ considering how close the car is to the second locost book design, that can be used as a build manual
MikeFellows
posted on 21/9/09 at 01:16 PM Reply With Quote
While out and about i picked up 3 boxes of M12 Washers to space them out
I have a great bargaining tool for my build manual though....
they gave me double the amount of rose joints, and funnily enough called me this morning to ask for them back
martyn_16v
posted on 21/9/09 at 08:25 PM Reply With Quote
I hate to break it to you, but there is no build manual. Well, there is, but it's about 4 sides of A4, half of which is a list of crap to steal off the Sierra, and a feedback form
MikeFellows
posted on 22/9/09 at 07:19 AM Reply With Quote
oh well im getting on quite well without it
eddbaz
posted on 22/9/09 at 02:30 PM Reply With Quote
I told you slim had left town
New Topic New Reply
