midge
| posted on 21/9/09 at 01:15 PM |
Electrical problem??
Driving at the weekend my indicators started playing up and I noticed a plum of smoke coming from under the top steering column shroud. Further
investigation revealed it was coming from inside the indicator / main beam switch. The internal circuit board has partially burnt!! I can't
think why this could off occured, its an old Sierra switch but I'm worried there may well be a problem elsewhere in the loom. Does anyone know
if these switches are prone to failure? I've just got another from the scrappy and don't want to fit until I've investigated
further.
Cheers Steve
nitram38
| posted on 21/9/09 at 01:18 PM |
How long has it been working ok for?
If it has been working for a long time, then it might just be the switch
midge
| posted on 21/9/09 at 01:24 PM |
On the road a fortnight, but no issues during build and SVA.
| posted on 21/9/09 at 01:25 PM |
Could just be old contacts burning out. If it was a short the fuses should have blown (assuming you've fused it all properly)...
nitram38
| posted on 21/9/09 at 01:28 PM |
Check your lampholders for shorts and places where the loom might rub or pass hot stuff as well
rallyingden
| posted on 21/9/09 at 01:29 PM |
^^^^^^ Agree with Ben. Fuses should protect against short, suspect dampness / old contacts. You can always measure what current is being drawn from
the battery when you connect up new switch.
RD
midge
| posted on 21/9/09 at 01:31 PM |
Thanks, I'll have a check over as much of the loom as I can tonight.
