karlak
posted on 11/10/09 at 12:22 PM |
Few newbie questions.
Having given up my motorbikes, I am after something to take out for a blast on Sunday mornings etc.
I am not absolutely sure on whether to look for a CEC or BEC, but may go the CEC route as a less extreme drive - may even get the missus out
Anyway, I have a chance to go for a MK Indy with a 2.0 litre PINTO engine. So before I go and take a look, what should I really be looking at - I
understand the spec of the bolt on bits can dramatically increase the cost.
Also, assuming it is a "basic" Pinto car, what realistic performance figures could you expect ?
Cheers for any help.
[Edited on 11/10/09 by karlak]
daniel mason
posted on 11/10/09 at 12:37 PM |
i have never been in a pinto powered 7 but due to the weight of the car,i would imagine it will still be fairly quick.
carlknight1982
posted on 11/10/09 at 12:46 PM |
i would personally take less intrest in the engine than the overall build condition, an engine upgrade can be a fairly simple job when compared to
building the car itself, but if the build is of poor quality or standard then you could be buying a real headache. also make sure that it is correctly
registered on the V5 document if it has an age related plate or the donor plate as if its not you could be faced with trying to get it through an iva
test.
biggest thing with the pinto is to remember its an old smelly and crude anchor of an engine but can still give one hell of a drive if its been looked
after or "fettled"
001Ben
posted on 11/10/09 at 12:58 PM |
it might be worth putting where you are in the world as someone close to you might offer you a passenger ride in a CEC/BEC
karlak
posted on 11/10/09 at 02:54 PM |
Thanks guys - I will go and take a look. I guess it is better to have an age related plate then ?
lotusmadandy
posted on 11/10/09 at 04:32 PM |
Hi and welcome to the forum.
I have an MK indy and have just removed
the 2 litre pinto to replace with a zetec.
Yes the pinto is a heavy lump but once fettled and with a decent set of carbs,
as mine was, it is a very good engine that will give most hot tin tops a hard time.
I would be more bothered about an age related plate on cobra than a seven.
afj
posted on 11/10/09 at 04:44 PM |
there are plenty of cecs and becs (ther the best) in cambs and beds, if you come over to peterborough ill take you for a spin
eerrrrrrrrrrrrrrrr
A1
posted on 11/10/09 at 05:36 PM |
go bec... waaay better
cryoman1965
posted on 11/10/09 at 06:40 PM |
I would look at the build quality, added on bits from basic kit (tyres,seats,dash) and that the V5 is correct. You will still get a good drive from
most 2.0ltr pinto's.
HTH
Nige
P.S I have a 2.0ltr Pinto 4 sale.
http://www.locostbuilders.co.uk/viewthread.php?tid=50029
[Edited on 11/10/09 by cryoman1965]
karlak
posted on 12/10/09 at 09:30 AM |
HTH
Nige
Lovely looking car - How much would you be selling it for ? Although the local one I have come across does seem very good value, as long as the build
id up to scratch.
cryoman1965
posted on 12/10/09 at 11:55 AM |
you have u2u
