garage19
| posted on 4/4/04 at 07:49 PM |
Wishbone Brackets?
I have got to the point where i am bolting in my rear wishbones and have noticed that the brackets seem to be a little too wide for the bushes and
their metal inserts. When i go to torque up the bolts the bracket sides get pulled in quite a bit so that they are no longer parallel. Is this right,
or am i missing something?
It could probably be cured with some shims but MK don't mention anything about the need for these. Has any one else had this problem?
Thanks,
Doug.
| posted on 5/4/04 at 12:08 AM |
We used spacers to keep the brackets as they are, between 1~2mm depending on gap.
