Staple balls
| posted on 16/10/09 at 07:18 AM |
Rear drums.
Anyone got any photos of the SVA compatible arrangement for sierra drum brakes on an indy?
I seem to remember they need to be upside down or something? is there any way to get around it?
Cheers.
whitestu
| posted on 16/10/09 at 07:49 AM |
Drums go on the same as on the donor. I think it is disks that need the calipers fitting differently.
Mr Whippy
| posted on 16/10/09 at 08:42 AM |
You can't mount drums upsides down as you could not bleed them correctly since the bleed screw would be at the bottom of the slave cylinder.
Calipers are often flipped upsides down, like on my Falcon as it’s easy to take them off and bleed them away from the disk by blocking the piston.
