Jonte
posted on 5/4/04 at 07:14 AM |
Caster, kpi & camber for Indy?
Anyone here that can tell me angles and so on for the Indy.
I´m using Sierra parts and MK´s modified uprights.
Click it
mad-butcher
posted on 5/4/04 at 05:57 PM |
don't know about the angles but if thats your workshop it puts my f######g house to shame
tony
Jonte
posted on 4/7/04 at 07:49 AM |
Anyone????
I´m getting close to testdrive soon
Click it
alister667
posted on 4/7/04 at 08:13 AM |
What I did was set the caster to maximum using the mushroom inserts (I needed this for the SVA self centreing steering) and set camber and toe-in to
about neutral/zero.
I think hellfire posted some info on a more optimal set up for toe-in/toe-out. Have a search for that.
For the SVA to help the self-centring steering I set up with max castor and a bit of toe-out. Then I changed it after the test.
http://members.lycos.co.uk/alister667/
MK7
posted on 21/7/04 at 10:05 PM |
I set mine up for max castor and zero camber / toe. This worked well even for SVA self centring.
