New Topic New Reply
Author: Subject: wheel bearing - what to tighten it too
aka Keith
posted on 22/10/09 at 11:44 AM Reply With Quote
not at home at the moment. Anyone know what torque the nut should be wound up to on a sierra back end? when replacing the wheel bearing?
stevec
posted on 22/10/09 at 12:13 PM Reply With Quote
Mr Haynes says:
Rear Hub Nut: 250-290Nm / 185-214 lbft
Robbed from a Piston Heads thread.
Steve.
aka Keith
posted on 22/10/09 at 12:17 PM Reply With Quote
Thanks Steve.
cheers
Craig
posted on 22/10/09 at 02:31 PM Reply With Quote
VFT it is then Break out the big bar.
maximill666
posted on 22/10/09 at 02:37 PM Reply With Quote
Depends on which type you have fitted ,ball bearing type or taper roller bearings?
aka Keith
posted on 23/10/09 at 09:39 AM Reply With Quote
Maximill666, it is the taper roller bearing type. any ideas as to the correct torque?
Craig
maximill666
posted on 26/10/09 at 01:10 PM Reply With Quote
Craig
DO NOT torque them up the same as ball bearing types, you'll destroy the bearing. Taper roller bearings require end float clearance to function correctly.
Tighten them up with the ratchet just enough to ensure the seats are located correctly, then back the nut off until free.
Finally nip the nut back up until it just bites & then back it off quarter of a turn, which should give you the required end float. Job done.
New Topic New Reply
