couch22k
posted on 10/11/09 at 12:57 PM |
Acewell Speedo
Hi all.
Im just fitting a acewell speedo ect. to my MK .
Was just wanting some advice where the best place is to fit the magnet and receiver was.
Any photos would be a big help.
Cheers.
Myke 2463
posted on 10/11/09 at 02:20 PM |
I mounted the sensor on the back of the gearbox and the magnet on the prop flange. once calibrated the speedo is good. fuel gauge and temp, not so
good.
Mike
Bluemoon
posted on 10/11/09 at 03:02 PM |
Most people mount the speedo magnet and pickup on the diff flange as this does not move about..
Dan
whitestu
posted on 10/11/09 at 04:17 PM |
My sensor is on the prop just behind the UJ. I used slow setting epoxy and it has been fine.
Fuel and temp gauges work well also.
Stu
mad-butcher
posted on 10/11/09 at 05:54 PM |
mounted on rear upright
my acewell uses only one magnet
tony
russbost
posted on 10/11/09 at 06:00 PM |
I prefer to mount the magnet & sensor on a driveshaft as speed is slower & therefore less likely to fire magnet into space! Also saves
having to divide wheel circumference by diff ratio.
Myke 2463 if fuel/temp not working correctly, fuel can easily be corrected by using a resistor in addition to the sender resistance to get it to match
what the Acewell is looking for (they do come with a resistor soldered in to demonstrate the fuel gauge - you need to remove this to make it work
accurately) the unit is also switchable for 3 different resistances depending on your sender.
Re the temp gauge, would suggest the sender is perhaps not appropriately sited??? Mine is absolutely spot on.
mad-butcher
posted on 10/11/09 at 07:53 PM |
Russ
Just out of curiosity, the acewell I got of fleabay ( before I knew you did them ) came with a magnet that was mounted in a bolt sort of thing so all
I had to do was drill and tap the lobro, is that not the std acewell fitting
tony
whitestu
posted on 10/11/09 at 09:43 PM |
If sticking the magnet on, cut the threaded bit off.
I didn't muck about with any complicated calculations for getting the speed settings right. I just used my satnav and a bit of trial and error.
It's spot on now.
Stu
[Edited on 10/11/09 by whitestu]
couch22k
posted on 11/11/09 at 08:44 AM |
Cheers for the help, guess this is my job for the weekend.
Russ, thanks for getting me that replacement to me so fast.
russbost
posted on 12/11/09 at 10:27 PM |
Tony
Yes the standard magnet comes with a 6mm thread, but most people are far too lazy to drill & tap a thread (have to confess to being guilty on this
one!) & simply cut the thread off & araldite or similar the magnet on. Obviously it is actually far better to tap a thread & screw the
thing in!
Russ
