New Topic New Reply
Author: Subject: Handbrake lever location
EasyJimbo
posted on 11/11/09 at 02:22 PM Reply With Quote
Hi Guys
Has anyone got any pics of the location of their handbrake lever, is it central in the tunnel or offset?
thanks
J
be gentle I am new to all this :-)
blog: http://mkjimbo-mkindybuild.blogspot.com/
Flamez
posted on 11/11/09 at 02:36 PM Reply With Quote
here is mine central and sunken;
finished cockpit
finished cockpit
my build mac1motorsports
jack_t
posted on 11/11/09 at 02:37 PM Reply With Quote
i have mine slightly offset to the passengers side to give me more arm room
sorry bout the limited pic my car has yet to be unveiled to fellow builders
Charlie_Zetec
posted on 11/11/09 at 02:55 PM Reply With Quote
Sorry for the imminent thread hijack, but FAO Flamez; where did you get the edging trim used for your centre console? I could do with some of that, if you would be so kind!!
Flamez
posted on 11/11/09 at 03:05 PM Reply With Quote
The trim is large rubber u trim and the brush material is a dismantled letterbox draught excluder from B&Q
l0rd
posted on 11/11/09 at 04:16 PM Reply With Quote
MK1 Lagunas have the same material around the handbrake
Charlie_Zetec
posted on 11/11/09 at 04:40 PM Reply With Quote
Sorry, should have been more specific! I actually meant the smooth-edged, right angle along the top and side sections of the centre console.
Having said that, I have taken on board the letterbox suggestion! Do you know if it's IVA proof, or would I need a gaitor?
EasyJimbo
posted on 11/11/09 at 05:03 PM Reply With Quote
thanks guys, so looks like the choice is mine.
J
55ant
posted on 11/11/09 at 05:24 PM Reply With Quote
flamez, what dash is that? really smart, is it curved.rounded at the edges?
away from cars, now cycling and building TT bikes
blakep82
posted on 11/11/09 at 06:09 PM Reply With Quote
mine shall be on the right of the driver seat. bolted to the floor
________________________
jacko
posted on 11/11/09 at 06:58 PM Reply With Quote
this is mine
MK fiber glass seats
iscmatt
Contributor
Posts 1929
Registered 30/3/06
Location York
Member Is Offline
Photo Archive Go!
Building: - BUILT - 2.0 pinto indy, Kent Cam, zzr1100 carbs
posted on 14/11/09 at 08:43 PM Reply With Quote
mine is also offset, this was done by mistake by dad but actually worked out to give slightly more arm room! a bit like jack_t but not quite as obvious
major
posted on 16/11/09 at 06:13 AM Reply With Quote
handbrake
handbrake
Some adjustments on the brackets were made after this pic.
Ought to give you an idea.
marcel.
New Topic New Reply
